Arduino_Ethernet.ino:30:11: error: invalid suffix “c8ba496a89549a39aed0d94e22b650d” on integer constant
In file included from /home/bruce/sketchbook/libraries/blynkLibrary030/Adapters/BlynkEthernet.h:18:0,
from /home/bruce/sketchbook/libraries/blynkLibrary030/BlynkSimpleEthernet.h:20,
from Arduino_Ethernet.ino:26:
/home/bruce/sketchbook/libraries/blynkLibrary030/BlynkApiArduino.h: In member function ‘void BlynkApi::processCmd(const void*, size_t)’:
/home/bruce/sketchbook/libraries/blynkLibrary030/BlynkApiArduino.h:94:82: note: #pragma message: Good! Analog pins can be referenced on this device by name.
#pragma message(“Good! Analog pins can be referenced on this device by name.”)
Arduino_Ethernet.ino: In function ‘void setup()’:
Arduino_Ethernet.ino:35:15: error: ‘auth’ was not declared in this scope
What’s your set up? What’s your code?
Thanks for responding… I’m sorry I just saw this. haha
I don’t have the code I was trying to use…
And I’m not currently working on that project.
So, I’ll have to get back to you later when I do find it.
Again, thank you so much for responding!!
Two years later… I should think not
Welcome back. If you have another question, just start another (current) topic.
