Im looking for some help/adivse as to while i keep getting this error message “a function-definition is not allowed here before ‘{’ token”.
Its the “{” right below the void setup. iv tried variuos things with no luck.
Could anyone point me in the right direction.
Thanks in advance.
Adam.
#include <OneWire.h>
#include <Dhcp.h>
#include <Dns.h>
#include <Ethernet.h>
#include <EthernetClient.h>
#include <EthernetServer.h>
#include <EthernetUdp.h>
http://twitter.com/blynk_app
You’ll need:
- Blynk App (download from AppStore or Google Play)
- Arduino Mega 2560 board
example.
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// http://milesburton.com/Dallas_Temperature_Control_Library
OneWire ds(48); // on pin 48 (a 4.7K resistor is necessary) make sure you change this from the original pin 10 to an unused pin.
int adr;
float s1;
float s2;
float s3;
float s4;
float s5;
float s6;
float s7;
char auth[] = "d27bf6f0a098498a81a5c65dab79b851";
#define W5100_CS 10
#define SDCARD_CS 4
float SetPoint = 20; //temperature set-point
float Differential = 2; //temperature control differential
int Relay1 = 22;
int Relay2 = 23;
int Relay3 = 24;
int Relay4 = 25;
int Heater1 = 50;
int Heater2 = 51;
int Cooling = 28;
float temperature = NAN;
float lowAlarm = NAN;
float highAlarm = NAN;
int int_probe_type = 0; //convert char to int to use Switch case
int button_pressed = 0; //virtual button variable
// temperature control
BLYNK_WRITE(V11){
//reads the setppoint
SetPoint = param.asFloat();
BLYNK_WRITE(V12){
//reads the differential
Differential = param.asFloat();
BLYNK_WRITE(V32){
//reads low alarm
lowAlarm = param.asFloat();
BLYNK_WRITE(V33){
//reads high alarm
highAlarm = param.asFloat();
BLYNK_WRITE(V40){
//receive button state from Blynk App
button_pressed = param.asInt();
void HandleRLYControl(){
//if sensor not sending temperature turn relay OFF for safety
if (isnan(temperature) && Heater1 HIGH) {
Heater1 = false;
Heater2 = false;
digitalWrite(Heater1, LOW);
digitalWrite(Heater2, LOW);
else if (!isnan(temperature))
if(Heater1){
if (temperature < (SetPoint - Differential) && !Heater1 HIGH) {
digitalWrite(Heater1, HIGH);
digitalWrite(Heater2, HIGH);
Heater1 = true;
Heater2 = true;
else if (temperature >= SetPoint && Heater1 HIGH) {
Heater1 = false;
Heater2 = false;
if (Cooling){
if (temperature > (SetPoint + Differential) && !Cooling HIGH) {
digitalWrite(Cooling, HIGH);
Cooling = true;
else if (temperature <= SetPoint && Heater1 HIGH,Heater2 HIGH ) {
Heater1 = false;
Heater2 = false;
//Prevent relay trigger on bootup
pinMode(22, INPUT_PULLUP);
//Define the relay pins
pinMode(22, OUTPUT);
pinMode(23, INPUT_PULLUP);
pinMode(23, OUTPUT);
pinMode(24, INPUT_PULLUP);
pinMode(24, OUTPUT);
pinMode(25, INPUT_PULLUP);
pinMode(25, OUTPUT);
pinMode(26, INPUT_PULLUP);
pinMode(26, OUTPUT);
pinMode(27, INPUT_PULLUP);
pinMode(27, OUTPUT);
pinMode(28, INPUT_PULLUP);
pinMode(28, OUTPUT);
pinMode(29, INPUT_PULLUP);
pinMode(29, OUTPUT);
pinMode(30, INPUT_PULLUP);
pinMode(30, OUTPUT);
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth);
//Blynk.begin(auth, "blynk-cloud.com", 80);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8080);
// relay control- delay - turning off multiple relays with the return pump
void TurnRelaysOn()
digitalWrite(Relay2, HIGH);
digitalWrite(Relay3, HIGH);
BLYNK_WRITE(V1) // Set to your Buttons vPin
int pinValue = param.asInt(); // Get State of Virtual Button, Return pump
if (pinValue == 0); // if button off
digitalWrite(Relay2, LOW); // turn skimmer off
digitalWrite(Relay2, LOW); // turn Reactor off
if (pinValue == 1); // if button on
timer.setTimeout(3000, TurnRelaysOn);}
// to avoid delay() function!
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
Serial.println();
ds.reset_search();
delay(250);
return;
// Serial.print("ROM =");
for( i = 0; i < 8; i++) { //we need to drop 8 bytes of data
adr = (addr[7]);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
Serial.println();
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for ( i = 0; i < 9; i++) { // we need 9 bytes to drop off
data[i] = ds.read();
Serial.println();
// Convert the data to actual temperature
// because the result is a 16 bit signed integer, it should
// be stored to an "int16_t" type, which is always 16 bits
// even when compiled on a 32 bit processor.
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
fahrenheit = celsius * 1.8 + 32.0;
if(adr == 239) { //replace ??? with value of sensor number 1
s1 = celsius; //change celsius to fahrenheit if you prefer output in Fahrenheit
if(adr ==2 ) { //replace ??? with value of sensor number 2
s2 = celsius; //change celsius to fahrenheit if you prefer output in Fahrenheit
Serial.print(" Sensor 1 = ");
Serial.print(s1);
Serial.print(" Sensor 2 = ");
Serial.print(s2);
Serial.print(" Sensor 3 = ");
Serial.print(s3);
Serial.print(" Sensor 4 = ");
Serial.print(s4);
Serial.print(" Sensor 5 = ");
Serial.print(s5);
Serial.print(" Sensor 6 = ");
Serial.print(s6);
Serial.print(" Sensor 7 = "); //add or delete if you need more or less
Serial.print(s7);
Blynk.virtualWrite(V5, s1);
Blynk.virtualWrite(V6, s2);
Blynk.virtualWrite(V7, s3);
Blynk.virtualWrite(V8, s4);
Blynk.virtualWrite(V9, s5);
Blynk.virtualWrite(V10, s6);
Blynk.virtualWrite(V11, s7); //add or delete if you need more or less
