I have problems understanding the synching mechanism
I need to write a value from my app to a Node MCU on startup. I am using blynk.syncVirtual as described in the manual. I also tried blynk.syncAll, but to no avail. I am most likely doing something wrong…
#define MINUTE 60
#include <max6675.h>
char auth[] ="xxxxxxxx";
char ssid[] = "xxxxxxxxx";
char pass[] = "xxxxxxxxx";
int ktcSO = 12;
int ktcCS = 13;
int ktcCLK = 14;
int NumberOfMinutes;
MAX6675 ktc(ktcCLK, ktcCS, ktcSO);
//SimpleTimer TempTimer;
BLYNK_CONNECTED() {
  // Request Blynk server to re-send latest values for all pins
  Blynk.syncVirtual(V1);
  Serial.println("In sync routine");
BLYNK_WRITE(V1)
  NumberOfMinutes = param.asInt(); // assigning incoming value from pin V1 to a variable
  Serial.print("V1 Slider value is: ");
  Serial.println(NumberOfMinutes);
void StuurTemperatuur()
  float DC = ktc.readCelsius();
  Blynk.virtualWrite(V5,DC);
void StuurBatterijLevel()
  int vcc = ESP.getVcc();
  Blynk.virtualWrite(V6, vcc);
  Serial.print("Battery level...: ");
  Serial.println(vcc);
  Serial.print("Sleeptime...: ");
  delay(100);
   ESP.deepSleep(MINUTE * 1000000);
     //wait until connected
  StuurTemperatuur(); // send temperature
  StuurBatterijLevel(); // send battery level
When I start the serial monitor, I see following, hence concluding that the value from the value from the virtual pin is not copied. The other thing I noticed is that apparently the Blynk_connected routine is called twice.
[17365] Connecting to Sitecom0E4486
[18867] Connected to WiFi
[18867] IP: 192.168.1.113
[18868]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.4.6 on NodeMCU
[18941] Connecting to blynk-cloud.com:8442
[19257] Ready (ping: 2ms).
In sync routine
[24258] Connecting to blynk-cloud.com:8442
[24327] Ready (ping: 3ms).
In sync routine
Battery level...: 65535
Sleeptime...: 0
Some additional information:
  • iOS app
  • Arduini 1.8.2
Any suggestions would be greatly appreciated. Thanks.
PS: Battery level is not exctly working either, but that’s not my main issue.
Solved: upgrading to the newest Blynk library did the trick
Make sure to mark as solved :slight_smile:
Thanks for the reminder, I was looking for this option…
No worries, I did it for you.
