Add details :
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
Arduino: 1.8.7 (Windows 10), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
NodeMCU:6:1: error: stray '\223' in program
char auth[] = “xxxx”;
NodeMCU:6:1: error: stray '\224' in program
NodeMCU:7:1: error: stray '\223' in program
char ssid[] = “GWTSVR-MUNEER 9749”;
NodeMCU:7:1: error: stray '\224' in program
NodeMCU:8:1: error: stray '\223' in program
char pass[] = “72801%eT”;
NodeMCU:8:1: error: stray '\224' in program
NodeMCU:6:16: error: 'xxxx' was not declared in this scope
NodeMCU:7:16: error: 'GWTSVR' was not declared in this scope
NodeMCU:7:23: error: 'MUNEER' was not declared in this scope
NodeMCU:8:22: error: 'eT' was not declared in this scope
Multiple libraries were found for "BlynkSimpleEsp8266.h"
Used: C:\Users\Muneer\Documents\Arduino\libraries\blynk-library-master
Not used: C:\Users\Muneer\Documents\Arduino\libraries\Blynk
exit status 1
HI Costas It worked m after reinstalling the IDE 1.8.8 and updated the Esp8266 libraries
Thank you dear , can you tell me which version wemos is better for professional use
