Ok costas i will see it!
wanek.What about this connection?Is necessary to put pull up resistors like in arduino?
the version of blynk is 0.4.10
yeah, it is clear now, you are correct of course with the pullups! i interpreted incorrectly the first drawing, my bad!
just make sure the leds do not draw too much current from the digital pins. it is good practice to put a current limit resistor in serial with the leds. if i remember correctly, max 12mA / digital pin is allowed on esp82.
Hello guys.Finally i didn’t complete the project with the nonemcu.I spent so many hours and i didn’t find the solution(for not working) because after of many many efforts i broke it because of my nerves(in the end i regret but too late.)So decided to use an ethernet shield that i had with arduino uno.I took this project https://examples.blynk.cc/?board=ESP8266&shield=ESP8266%20WiFi&example=More%2FSync%2FSyncPhysicalButton
and here i added 2 extra buttons+led.
The only problem that i notice is that when there is not ethernet,the natural buttons does not react completely wright.
http://twitter.com/blynk_app
This example shows how to synchronize Button widget
and physical button state.
App project setup:
Button widget attached to V2 (Switch mode)
#include <Ethernet.h>
char auth[] = "9e03981a27ad4f4ea28389ca95f58028";
#define W5100_CS 10
#define SDCARD_CS 4
// Set your LED and physical button pins here
const int ledPin1 = 6;
const int btnPin1 = 2;
const int ledPin2 = 8;
const int btnPin2 = 3;
const int ledPin3 = 9;
const int btnPin3 = 5;
void checkPhysicalButton();
int ledState1 = LOW;
int btnState1 = HIGH;
int ledState2 = LOW;
int btnState2 = HIGH;
int ledState3 = LOW;
int btnState3 = HIGH;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
Blynk.syncVirtual(V2);
Blynk.syncVirtual(V3);
Blynk.syncVirtual(V4);
// Alternatively, you could override server state using:
//Blynk.virtualWrite(V2, ledState);
// When App button is pushed - switch the state
BLYNK_WRITE(V2) {
ledState1 = param.asInt();
digitalWrite(ledPin1, ledState1);
BLYNK_WRITE(V3) {
ledState2 = param.asInt();
digitalWrite(ledPin2, ledState2);
BLYNK_WRITE(V4) {
ledState3 = param.asInt();
digitalWrite(ledPin3, ledState3);
{ //FOR BUTTON1
if (digitalRead(btnPin1) == LOW) {
if (btnState1 != LOW) {
// Toggle LED state
ledState1 = !ledState1;
// Update Button Widget
Blynk.virtualWrite(V2, ledState1);
btnState1 = LOW;
btnState1 = HIGH;
//FOR BUTTON2
if (digitalRead(btnPin2) == LOW) {
if (btnState2 != LOW) {
// Toggle LED state
ledState2 = !ledState2;
Blynk.virtualWrite(V3, ledState2);
btnState2 = LOW;
btnState2 = HIGH;
//FOR BUTTON3
if (digitalRead(btnPin3) == LOW) {
if (btnState3 != LOW) {
// Toggle LED state
ledState3 = !ledState3;
Blynk.virtualWrite(V4, ledState3);
btnState3 = LOW;
btnState3 = HIGH;
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth);
//Blynk.begin(auth, "blynk-cloud.com", 8442);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8442);
pinMode(ledPin1, OUTPUT);
pinMode(btnPin1, INPUT_PULLUP);
pinMode(ledPin2, OUTPUT);
pinMode(btnPin2, INPUT_PULLUP);
pinMode(ledPin3, OUTPUT);
pinMode(btnPin3, INPUT_PULLUP);
// Setup a function to be called every 100 ms
timer.setInterval(100L, checkPhysicalButton);
Wanek sorry for the code.I can’t understand how realy works Preformatted text
Don’t bother with the </> method, it doesn’t always work.
Just type in three back-tick characters, the three letters cpp then paste your code and enter three more back-tick characters.
