I’m new in Blynk and I love this program because it can send emails! I want to make a simple program : reading data from a DHT11. I ran DHT11 , I ran ./blynk-ser.sh to connect to blynk server, but you wait and wait and it doesn’t connect to server. I’m using linux. Here is the code:
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you’ll need SimpleTimer library:
https://github.com/jfturcot/SimpleTimer
and Adafruit DHT sensor libraries:
https://github.com/adafruit/DHT-sensor-library
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
#include <BlynkSimpleSerial.h>
#include <DHT.h>
char auth[] = " 3c37e93440b04319b8d0bab86cfaa497";
#define DHTPIN A0 // What digital pin we’re connected to
// Uncomment whatever type you’re using!
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
// This function sends Arduino’s up time every second to Virtual Pin (5).
// In the app, Widget’s reading frequency should be set to PUSH. This means
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
Serial.println(“Failed to read from DHT sensor!”);
return;
// Please don’t send more that 10 values per second.
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
Blynk.begin(auth);
dht.begin();
If anybody can help me , please write here.
Regards,
your Blynk user
