I WANT TO CONNECT THE BELOW COAD TO BLYNK SERVER
CAN YOU PLEASE SUGGEST WHAT TO DO BECAUSE I TRIED THE BLYNK BLINK COAD TO CHECK THE GSM I COULD NOT ACCESS THE BLYNK SERVER
I AM USING GSM/GPRS SHIELD TO DO SO
YOU DON’T NEED TO SHOUT, IT’S NOT VERY FRIENDLY!
Also, posting photographs of your screen isnt very effective. You should either use screen captures, or in this case simply copy and paste the data from the serial monitor.
Without seeing your code its very difficult to give an opinion. If you are going to post code then please use triple backticks at the beginning and end of the code so that it displays correct;y.
I solved the problems with GSM but when it gets to connect to blynk cloud…it’s not stable…works for 1-2 secs then disconnects again…is it because of blynk cloud error?
