Add details :
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
I am new at coding. I would like to build a simple thermostat with NodeMcu and the DHT22 temperature sensor. I become an error when debuging the code. With wirtual pin V1 I would like to turn the regulation on and off
#define grelci D1, OUTPUT
float maxtemp = 27;
int pinValue;
#include <DHT.h>
char auth[] = " xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxxxx";
char pass[] = "xxxxxx";
#define DHTPIN D2 // What digital pin we're connected to
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
if (t < maxtemp && pinValue == 1 ){
digitalWrite(grelci, HIGH);}
digitalWrite(grelci, LOW);
BLYNK_WRITE(V1)
int pinValue = param.asInt();
dht.begin();
Then you could add in a “flag check” with if() command to determine if you want to run the temp scan or not, depending on the value of the Widget on V1.
Thank you for answer. I changed the code, but it still does not work.
This is my new code:
float maxtemp = 27;
int pinValue;
#include <DHT.h>
char auth[] = " xxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxx";
char pass[] = "xxxxxxx";
BLYNK_WRITE(V1)
void sendSensor()
if (pinValue == 1){
if(t < maxtemp){
dht.begin();
#define grelci D1
int maxtemp;
int pinValue;
#include <DHT.h>
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
char pass[] = "xxxxxxxxxxx";
void sendSensor()
return;
if(t < maxtemp && pinValue == 1) {
}else{
BLYNK_WRITE(V1)
BLYNK_WRITE(V3)
maxtemp = param.asInt();
pinMode(grelci, OUTPUT);
dht.begin();
timer.setInterval(1000L,sendSensor);
If I were you I’d change the “pool” time as per spec, the DHT22 doesn’t like (if I recall correctly) to be “pooled” with a sampling rate higher than 0.5Hz (once every 2seconds) even though it works.
Guys, I’m gonna use your tips and solutions. I’m working on software documentation where I try to cover most problems that I found by myself or which others encountered and come out with the solution. Maybe one day my documentation will become a book about programming or will be part of another one’s book, in the support section. I’m working with DOCSIE, and if you guys will someday have to manage a lot of text, which will be embedded in a website, feel free to use it too. A great app for managing text.
