I’m trying to perform OTA via Blynk Local Server, but after first configuration to implement OTA functionality when I try to start with an OTA update I get following error:
- Trying ipmyhostname…
- TCP_NODELAY set
- Connected to myhostname (ipmyhostname) port 9443 (#0)
- schannel: SSL/TLS connection with myhostname port 9443 (step 1/3)
- schannel: disabled server certificate revocation checks
- schannel: verifyhost setting prevents Schannel from comparing the supplied target name with the subject names in server certificates.
- schannel: sending initial handshake data: sending 177 bytes…
- schannel: sent initial handshake data: sent 177 bytes
- schannel: SSL/TLS connection with myhostname port 9443 (step 2/3)
- schannel: failed to receive handshake, need more data
- schannel: encrypted data got 1127
- schannel: encrypted data buffer: offset 1127 length 4096
- schannel: sending next handshake data: sending 126 bytes…
- schannel: encrypted data got 51
- schannel: encrypted data buffer: offset 51 length 4096
- schannel: SSL/TLS handshake complete
- schannel: SSL/TLS connection with myhostname port 9443 (step 3/3)
- schannel: stored credential handle in session cache
- Server auth using Basic with user ‘admin@blynk.cc’
POST /admin/ota/start HTTP/1.1
Host: myhostname:9443
Authorization: Basic YWRtaW5AYmx5bmsuY2M6YWRtaW4=
User-Agent: curl/7.55.1
Accept: /
Content-Length: 803314
Expect: 100-continue
Content-Type: multipart/form-data; boundary=------------------------9282d35c41289c3b
- schannel: client wants to read 102400 bytes
- schannel: encdata_buffer resized 103424
- schannel: encrypted data buffer: offset 0 length 103424
- schannel: encrypted data got 120
- schannel: encrypted data buffer: offset 120 length 103424
- schannel: decrypted data length: 60
- schannel: decrypted data added: 60
- schannel: decrypted data cached: offset 60 length 102400
- schannel: encrypted data length: 31
- schannel: encrypted data cached: offset 31 length 103424
- schannel: server closed the connection
- schannel: schannel_recv cleanup
- schannel: decrypted data returned 60
- schannel: decrypted data buffer: offset 0 length 102400
< HTTP/1.1 413 Request Entity Too Large
< content-length: 0 - HTTP error before end of send, stop sending
< - Closing connection 0
- schannel: shutting down SSL/TLS connection with myhostname port 9443
- schannel: clear security context handle
My .bin file is of 803088 byte.
How can I solve this problem? I don’t understand if there is a configuration parameter related to local Blynk Server to increase possible file size?
I have Esp32 Sparkfun Thing module with last Blynk library version and Blynk Local Server (that runs on Raspberry Pi3 B+)
Let me know if you needs other infos.
Thanks.
Regards
