Http api can I put more values?
Hello everyone, I have a question about the api http, how can I write more values ​​on a single Pin? In the guide there is the example for the put method, but speaks of a single value. Thanks for the answers.
One pin can only ever have one value at any given time. A fraction of a second later you can write another value.
Maybe explain what you would like to do so we can provide an answer to your real problem.
I would write more values ​​as the bridge function where I can write more values ​​on a Pin and then retrieve it via paramasint method but through http api
The solution for now would be to use multiple pins. I think they are working on making this possible though. It’s a much wanted feature, I could do with it too for my Lamp projects :slight_smile:
@Thomas and @Lichtsignaal wouldn’t you be able to code the same effect of a pin having multiple values?
So for example if you wanted to send speed and direction to a motor a pin could hold something like 100C for 100 rpm in a clockwork direction and 140A for 140 rpm in an anti clockwork direction.
Current HTTP API was designed for widgets handling. So in other words if you don’t have widget you are not able to store/get value. But idea is good. I’ll implement it soon. I created ticket for that.
It’s possible, but you have to create your own “protocol” for that. I’m facing similar issues with my Lego Trains, I still have no idea how to fix that.
At this point I’m considering using the infamous DCC protocol and build decoder for Lego Trains based on that. In the end I can probably control my trains using standard railroad modeling software like iTrain or maybe even the Roco MultiMouse and such.
Practically, I would like to convey 12 values from a Python application residing on Rapberry PI (which is also the installayto Blynk server) to the thermostat / Arduino, I thought I could use the pins as a communication channel via http api, since Python has no libraries for Blynk.
Anyway thanks again for the support, I’ll wait for this to be implemented.
@Thomas do you need just last stored values? Or you need also history data for those values?
@Costas @Thomas @Lichtsignaal by the way feature is already implemented for 0.16.4 server.
through a program in Python on raspberry where also stay Blynk server, I get data from internet and would like to make them available to all devices connected to Blynk server, it would be able to enter up to 12 values ​​at Pin, but I do not need the history
Great! Really thank you
Is this feature confirmed to be working?
I am trying it out on local sever 0.16.4 but it only works if I have a widget with the Vpin on my dashboard.
I can write multiple values to the single Vpin which is great.
Blynk.virtualWrite(V120, 1111,1234,6969);
Blynk.syncVirtual(V120);
Then I’m expecting this function to run and give me a serial output, but it only works if I have the Vpin 120 allocated on my dashboard.
BLYNK_WRITE(V120)
int x = param[0].asInt();
int y = param[1].asInt();
int z = param[2].asInt();
Serial.print("Read from V120 x value - ");
Serial.print(x);
Serial.print(" y value - ");
Serial.print(y);
Serial.print(" z value - ");
Serial.println(z);
@NickMurray hello. This feature you are describing is called Sync for Non widget pins and it was implemented as part of Sync bridge feature :slight_smile: and will be available in 0.17.0. 0.17.0 release will come in few days.
Very nice work. @Dmitriy
Really sorry but I can not communicate with the server api, which port should I use? If I start the call by a program who is on the same Blink server machine it works?
(ps I use the 17 blink server version)
Default port is 8080 for http and 9443 for https.
Yes.
Thank you @Dmitriy, I try but I always get “connection refuse”
I use this code get from apiary on blink api section.
`from urllib2 import Request, urlopen
values = “”"
“1”,
“2”
headers = {
‘Content-Type’: ‘application/json’
request = Request(‘http://192.168.0.200/authid/pin/V11:8080’, data=values, headers=headers)
request.get_method = lambda: ‘PUT’
response_body = urlopen(request).read()
print response_body`
I’ve modified with my authid and my ip Blink server address
Update: I’ve modified the code and now I get error 400
Thi is the code:
values = “”"
“1”,
“2”
headers = {
request = Request(‘http://192.168.0.200:8080/authid/pin/V11’, data=values, headers=headers)
@Thomas what exactly error says?
