How to use simple timer function?
how to use simple timer function? when i used delay function the following program working properly but when i used simpletimer fuction the LED notification on dashboard is turns ON for few seconds and then it turns off. I want LED notification when LED connected to pin13 is turn ON.
#include <ESP8266_HardSer.h>
#include <BlynkSimpleShieldEsp8266_HardSer.h>
// Set ESP8266 Serial object
#define EspSerial Serial
    ESP8266 wifi(EspSerial);
    char auth[] = "auth token";
    int prev = -1;
    int B1V;
    int BUTTON1 = 13;
      // Set console baud rate
    // Set ESP8266 baud rate
      EspSerial.begin(9600);
      Blynk.begin(auth, wifi, "saurabh", "saurabh0639");
    void sendUptime()
    B1V = digitalRead(BUTTON1);
    if (B1V != prev) {
    if (B1V) {
    Blynk.virtualWrite(V1, 255);
    Blynk.virtualWrite(V1, 0);
      timer.run(); // SimpleTimer is working
Have you checked if the hardware is responsible for this? Seeing as pin 13 is the built-in LED, you can actually check very quick to see if the LED is indeed on or off.\
-edit-
I think you are overthinking this:
void sendUptime()
  int button1 = digitalRead(13);
  if(button1 == 0)
    Blynk.virtualWrite(V1, LOW);
    Blynk.virtualWrite(V1, HIGH);
