I have entered
URL :- http://188.166.206.43/myauthkey/update/D7
Method:
PUT
Content Type:
application/json
Body:
[“1”]
It`s not working
Please help me
how to ping By using CMD can you please tell me the procedure
What OS are you using?
windows
DOS / CMD prompt then simply
ping blynk-cloud.com
Thank you so much I am gonna try this
Ans what about content type and body
json and no body. If you checked the GET syntax you will see the “body” is in the url.
I am trying it with IFTTT using webhooks
and details are
URL:- http://188.166.206.43/Myauth/update/D2?value=1
Method :- GET
content type :- application/json
BODY:- empty and I`ve also tried with [“1”]
please help ASAP
Does it work when you bash the url in a browser?
What MCU are you using?
Looks like it’s not connected / you have the wrong IP / the wrong token.
Always test the api in a browser before trying IFTTT etc, if it don’t work in a simple browser it’s never going to work in laggy IFTTT.
Presumably it also fails with the following url:
http://[IP]/[token]/project
I am using Node MCU V3 ESP8266 board
For ip I am using CMD as you can see in image
please tell me how to use it in browser atleast
But is this the same IP as the server that your MCU is connected to?
Are you in the same location as the MCU?
Yes both my laptop and esp8266 is connected to same WIFI network And for WIFI I am using here is my android mobile as hotspot
You don’t have regular internet available?
Your ESP is connected to the internet? How do you know it is?
Try changing the IP in the url to blynk-cloud.com
Hello this is akshay
because I am able to control led using blynk app which is working on regular internet and it shows device status online so it is connected to internet i am sure about this
