Does this mean, that I can add the Blynk App directly to Google Home like shown on the screenshot?
And then I can control blynk with voice command?
Maybe it is that simple and this is why no-one is talking about it.
it is Sinric that passes your Google Home voice commands to your Blynk App. & ESP8266.
you need to get Sinric first then add it to your working Blynk sketch.
here you can find examples
This seems to be double up. Now we have another server involved. Why can Google not connect with the Blynk server?
i think blynk team not doing that because
- it will make grip more users to use Blynk cloud just as a gateway server to redirect the requests to GH or Alexa
- will raise the operation cost of blynk servers because of the undesired traffic and processing power required etc.
- it will take the great blynk platform out of it’s scope.
- this should be in the paid plans so blynk still continue generating revenue and keep the R&D for more great features
everybody knows that the blynk power we purchased for almost no money is way far from even the servers cost
no need to mention the development team and rent , etc i think @Dmitriy and the rest of the great team should know the we like there platform an wish them a great future
This is in our roadmap. We are limited in resources so we have to prioritize new features.
The server cost is covered, no worries here .
This was Pavel (Founder of Blynk) answer for “Is there plans for Google Home support?” few lines above ( post 3)
I am able to use IFTT and Blynk with Google Home, but I now want to make it stateful, for example when I say turn on the lights, it actually checks the status and only turn on if it is off, or tells me that the lights are already turned on, is that possible - Thanks
Yes.
can you point me in right direction, like where to start from or any tutorial if you can suggest - Thanks
As I see you are a new user just joined now
you need to read more and you will find all your answers in this topic .
raxy
Rakesh Sharma
Last Post: 12 mins
Seen: 12 mins
Trust Level: new user
Ze_Pico, thanks a lot for sharing this info! Realy cool! The only problem I have now (or rather inconvenience), that I have window blinds and they have the position from 0 (closed) to 100 (opened) and there is no compatible device for them. I’m forced to use lights device for the blinds as it has the needed action (brightness). Everything works fine with no delay, just sounds a bit confusing, when the Google says, that it sets up the brightness for the blinds
@shur1k
Hi
We have to wait. I think it will be available soon for GH.
for Amazon Alexa you can build you own skill .
other solutions that works
now they use MySmartBlinds application instead
if you are using a stepper motor for your Blinds here is a good video for HA and Alexa.
@Ze_Pico, thanks for the info. Didn’t want to mix Alexas with GH, But… maybe it’s worth doing. We’ll see.
Node Red nodes for Sinric
Installation
node-red-contrib-sinric-ws
is not published to NPM repo yet because it is still in premature stage and experimental. If you want to experiment with you, you’ll have to manually install it using following steps.
- Goto to your Node Red user directory.
- In Linux/Mac, it’s usually in
~/.node-red
- In Windows, it will be under
C:\Users\<Your Username>\.node-red
- Run the following command:
npm install mayankraichura/node-red-contrib-sinric-ws
- Restart Node-Red.
ALEXA IKEA BLIND CONTROLLED BY VOICE
Libraries that work with SINRIC
Adding ArduinoJson
Download the zip file from https://github.com/bblanchon/ArduinoJson/releases/tag/v5.13.2 (6.x versions are not compatible)
Arduino IDE -> Sketch - Include Library -> Add Zip Library
Adding arduinoWebSockets
Download the zip file from https://github.com/Links2004/arduinoWebSockets/releases
don’t try to update these 2 libraries your sketch will not work
More SINRIC Arduino Examples you can use with BLYNK
Sinric Pro is comming soon
I don’t know if it will stay Free, but what I knew with “Google Home” you will not have to unlink then relink “[test] Sinric” with your application each month.
A Sinric alternative.
Control (almost) anything with Google Assistant™…
https://about.gbridge.io/
Documentation
https://doc.gbridge.io/index.html
