How to use Blynk lib in Mongoose-os?
There is one blynk lib implemented with mongoose-os.
It is written using C, and only finish part of blynk’s protocol.
I want to use the 0.50 lib, then which step do i need to do?
This library is not available for Mongoose OS as is. You could try porting it - this should be pretty doable.
