How to turn on and off relay when temp reach temp
Hi All,
i have a question, i have a nodemcu and its connected to blynk serverm i have 1 temp sensor on Virtual port and one relay port,
i do i set the relay to open and close when the temp is high and low ?
  • DS18B20 Temperature Sensor */
/#include <OneWire.h>
#include<DallasTemperature.h>
#define ONE_WIRE_BUS 2 // DS18B20 on arduino pin2 corresponds to D4 on physical board
DallasTemperature DS18B20(&oneWire);
float temp;
  DS18B20.begin();
  timer.setInterval(1000L, getSendData);
 * Send Sensor data to Blynk
void getSendData()
  DS18B20.requestTemperatures();
  temp = DS18B20.getTempCByIndex(0);
  Serial.println(temp);
  Blynk.virtualWrite(10, temp); //virtual pin V10
attached code
thanks
Please format your code correctly before support can be provided.
```cpp
CODE
