I want to transfer a tab to an other exising project instead of starting all over again
is there a way to do it?
using local blynk server
There is no such feature, unfortunately
You can clone, and then delete the widgets and tabs you don’t need.
yes but clonning is for a new project, not to add on an existing dashboard.
don’t worry.
thank you for your help.
I have never tried it, but I believe you can try to copy/paste from the relevant youremail@gmail.com.Blynk.user
JSON files (I believe that is what they are called) in Local Server (if you use that)… But if not careful you may end up with a bit of a mess.
@Gunner
I split blynk.user with microsoft word, 52 pages !!!
too complicated but interesting !!!
"tabs":[{"id":0
"label":"Thermostat"}
{"id":0
"label":"programmation"}
{"id":0
"label":"Alarme"}
{"id":0
"label":"widget"}]
"bubbleOn":false
"textColor":0}
{"type":"LCD"
"id":80632
"x":0
"y":1
"color":1602017535
"width":8
"height":2
"tabId":0
"isDefaultColor":false
"deviceId":0
"advancedMode":true
"textFormatLine1":"Température /pin0./ °C"
"textFormatLine2":"Humidité /pin1./ %"
"textLight":true
"frequency":0
Google for JSON editors
yes, but microsoft word do the same with 2 mouse clics
I have to understand the structure , but I will spend less time starting over !
only 18 buttons
I am also learning about JSON… I loaded a basic Chrome App JSON editor and can finally see how it looks.
This is one of my simple projects… a whole whopping two buttons for my two Sonoffs
"id": 304879542,
"parentId": -1,
"isPreview": false,
"name": "Sonoff",
"createdAt": 1523421348656,
"updatedAt": 1526951772859,
"widgets": [
"type": "BUTTON",
"id": 99836,
"x": 1,
"y": 1,
"color": 79755519,
"width": 2,
"height": 2,
"tabId": 0,
"label": "Shower RGB",
"isDefaultColor": false,
"deviceId": 0,
"pinType": "VIRTUAL",
"pin": 0,
"pwmMode": false,
"rangeMappingOn": false,
"min": 0,
"max": 1,
"value": "1",
"pushMode": false
"type": "BUTTON",
"id": 182682,
"x": 5,
"y": 1,
"color": -308477697,
"width": 2,
"height": 2,
"tabId": 0,
"label": "Closet Light",
"deviceId": 64193,
"pin": 0,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0.0",
"pushMode": false
"devices": [
"id": 0,
"name": "Sonoff I",
"boardType": "ESP8266",
"token": "43f4edf886xxxxxxxxxx3c6d0c5d3",
"vendor": "Sonoff I",
"connectionType": "WI_FI",
"status": "ONLINE",
"disconnectTime": 1526951770672,
"connectTime": 1526951772763,
"lastLoggedIP": "10.10.3.195",
"hardwareInfo": {
"version": "0.5.2",
"boardType": "Arduino",
"build": "Apr 28 2018 02:24:49",
"heartbeatInterval": 10,
"buffIn": 1024
"isUserIcon": false
"id": 64193,
"name": "Sonoff II",
"token": "abb266472xxxxxxxxxx16ad9661e0",
"vendor": "Sonoff II",
"status": "ONLINE",
"disconnectTime": 1526949591902,
"connectTime": 1526950031511,
"lastLoggedIP": "10.10.3.198",
"hardwareInfo": {
"version": "0.5.2",
"build": "Apr 28 2018 02:24:51",
"buffIn": 1024
"isUserIcon": false
"theme": "Blynk",
"keepScreenOn": true,
"isAppConnectedOn": false,
"isNotificationsOff": false,
"isShared": false,
"isActive": true,
"widgetBackgroundOn": false
Interesting how the hardwareInfo
thinks they are Arduinos
ESP8266 IS Arduino in this scenario. It uses Arduino Core!
Anyway, Arduino mean that library couldn’t detect model more precisely. It should not matter for community edition projects.
