hello guys i have made a project that control the light switch on&off through google Assistant with the help of this video i made it “https://www.youtube.com/watch?v=5SvRolROPxA” and i have integrated temperature sensor to the nodemcu and the readings are from nodemcu and displayed via blynk app and now what i need is if ask google assistant about my room temperature it should get reading from node mcu and tell me the temperature this is the code i have used
#include <DHT.h>
// float DHT11_h;
// float DHT21_h;
char auth[] = "XXXXXXXXXXXXXXXXX5";
char ssid[] = "home WIFI";
char pass[] = "shXXXXXXXX";
DHT dht1(D7,DHT11);
DHT dht2(D8,DHT11);
void sendSensor()
float DHT11_h = dht1.readHumidity();
float DHT11_t = dht1.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(DHT11_h) || isnan(DHT11_t)) {
return;
Blynk.virtualWrite(V5, DHT11_h);
Blynk.virtualWrite(V6, DHT11_t);
//sensor 2
float DHT21_h = dht2.readHumidity();
float DHT21_t = dht2.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(DHT21_h) || isnan(DHT21_t)) {
return;
Blynk.virtualWrite(V3, DHT21_h);
Blynk.virtualWrite(V4, DHT21_t);
BLYNK_WRITE(V1)
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
Serial.print("V1 Slider value is: ");
Serial.println(pinValue);
dht2.begin();
dht1.begin();
and the mechanism how my google and nodemcu working is on requesting anything from my mobile is
google assistant–>IFTTT–>Webhook–>blynk server request–>nodmcu
and now i need reverse of that mechanism please any ideas or anyone help me with this issue
