I am trying to read data from virtual port V2 and Display on Serial monitor.
I have used slidebar for v2 if v2 has changed then Serially it should printed .
How can used in loop()
BLYNK_READ(V5) //Blynk app has something on V5
sensorData = analogRead(A0); //reading the sensor on A0
Blynk.virtualWrite(V5, sensorData); //sending to Blynk
BLYNK_WRITE(V2) {
int counter = param.asInt();
Serial.print(counter);
Here is my code to read data . I have used DHT11 . i want to set temprature through slider . If slider value chage > setvalue turn on relay else turn off relay/
Serially It wont print any changed values
#include "DHT.h"
#include "Wire.h"
#include"glob.h"
DHT dht;
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxx"; // You should get Auth Token in the Blynk App.
char ssid[] = "HOT SPOT"; // Your WiFi credentials.
char pass[] = "Test123"; // Set password to "" for open networks.
dht.setup(D3);
timer.setInterval(2000, sendUptime);
pinMode(D4,OUTPUT);
pinMode(D5,OUTPUT);
pinMode(D6,OUTPUT);
BLYNK_READ(V2)
int pinValue = param.asInt();
if(pinValue>=temperature)
digitalWrite(D5,HIGH);
}else
digitalWrite(D5,LOW);
BLYNK_WRITE(V2) {
Blynk.virtualWrite(V2, counter);
void sendUptime()
delay(dht.getMinimumSamplingPeriod()); /* Delay of amount equal to sampling period */
humidity = dht.getHumidity(); /* Get humidity value */
temperature = dht.getTemperature(); /* Get temperature value */
Serial.println("Humidity and temperature\n\n");
Serial.print("Current humidity = ");
Serial.print(humidity);
Serial.print("% ");
Serial.print("temperature = ");
Serial.print(temperature);
Blynk.virtualWrite(V0, temperature);
Blynk.virtualWrite(V1, humidity);
This statement is redundant. Why write the same value that you are reading as input?
Just as @ldb asked, what does your monitor show? That will be the clue to what is happening. Serial.print like what you are using works well and has been so fro quite some time.
