How to read data from blynk in void loop?
I want to read data from blynk in void loop like this.
      Serial.println("low_humid " + low_humid );
    BLYNK_WRITE(V0)
      low_humid = param.asInt();
The output show text “low_humid” only not show value. How to fix it?
I think you’re misunderstanding the purpose of the BLYNK_WRITE function. It doesn’t write data to the app.
Also, you can’t use delays in the void loop with Blynk, you need to use a timer instead.
Start by reading this:
Thank you
