Dear Everyone
Is it possible to send multiple blynk PIN value to esp8266 using a Save, submit button on Blynk app?
For an example. , On blynk app I have 2 textbox wiget vpin10 and vpin11, and after entering my value to them, i click “Save” button, I want to send the value of those vpin back to esp8266.
If the “save” button triggered the commands Blynk.syncVirtual(V10)
and Blynk.syncVirtual(V11
the you could get it to work.
Dear Pete
i wrote this, when the
button (vpin127) pressed BLYNK_WRITE(V127) fire, but it doesnt call to BLYNK_WRITE(V10) and BLYNK_WRITE(V11) method. Can you help ?
BLYNK_WRITE(V10) {
//code
BLYNK_WRITE(V11) {
//code
BLYNK_WRITE(V127) {
Blynk.syncVirtual(V10);
Blynk.syncVirtual(V11);
@Anthony_Chen please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Thanks Pete
I did it, now code displayed
It looks like it should work, but without seeing the full code and understanding what you are seeing when the various widget buttons are pressed and how you have your app configured it’s difficult to say why it’s not working.
Dear Pete
When i pressed the button (vpin127), i can see serial print “Saving” and “Saving Done”, but serial not print “trace1” and “trace2” , just like the method not call
V10 and V11 on blynk app are text input widget, i enter some int value like 5, 10 to test
BLYNK_WRITE(V10) {
Serial.println("trace 1");
BLYNK_WRITE(V11) {
Serial.println("trace 2");
BLYNK_WRITE(V127) {
int pinValue = param.asInt();
if (pinValue == 1)
Serial.println("Saving");
Serial.println("Saving Done");
Thanks Pete
IDK why but after change vpin 10 and 11 widget on blynk app to numeric input, the value updated ok
Regards
