OK here is the full sketch:
#define Version "1.1"
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social networks: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* Blynk using a LED widget on your phone!
* App dashboard setup:
* LED widget on V1
* LED widget on V2
* WARNING :
* For this example you'll need SimpleTimer library:
* https://github.com/jfturcot/SimpleTimer
* Visit this page for more information:
* http://playground.arduino.cc/Code/SimpleTimer
#include <BlynkSimpleOak.h>
// Use Virtual pin 5 for uptime display
#define PIN_UPTIME V5
/// Use Virtual pin 3 for rebootToConfig() ///
#define REBOOT_TO_CONFIG V3
/// the bellow variables are for 3 sec push mode for V3 button in order to get in softAP mode ///
unsigned long previousMillis = 0; ///
const long interval = 3000; ///
unsigned long currentMillis = 0; ///
char auth[] = "Auth here";
WidgetLED led1(V1);
WidgetLED led2(V2); /// reports the actual logic of GP5 pin///
WidgetLCD lcd(V7);
// This function sends Arduino's up time every 4 seconds to Virtual Pin (6).
void sendTemperature()
// Generate random temperature value 00.0 to 18.0 (for example)
float t = float(random(000, 180))/10;
// Format: 1 decimal place, add ℃
String str = String(t, 1) + "℃";
String strV6 = String(t, 1);
// Send it to the server
Blynk.virtualWrite(V6, strV6);
lcd.clear(); //Use it to clear the LCD Widget
lcd.print(5, 1, str); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
lcd.print(1, 0, "The temp. is:");
Blynk.begin(auth);
/// initializing the GP5 that goes to the Relay, for output and set it to HIGH ("1") in order to have water heater Relay turned OFF ///
pinMode(5, OUTPUT); //LED on Oak
digitalWrite(5, HIGH); // turn the LED on (HIGH is the voltage level)
// Wait until connected
/// timer.setInterval(200L, fadeLedWidget);
// This function tells Arduino what to do if there is a Widget
// which is requesting data for Virtual Pin (5)
timer.setInterval(4000L, sendTemperature);
lcd.print(1, 0, "Not final yet!");
lcd.print(4, 1, "Ver=");
lcd.print(8, 1, Version); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
BLYNK_READ(PIN_UPTIME)
// This command writes Arduino's uptime in seconds to Virtual Pin (5)
Blynk.virtualWrite(PIN_UPTIME, millis() / 1000);
/// press V4 button in order to get the Software Version printed on app's screen ///
BLYNK_WRITE(V4)
if (param.asInt()) {
delay(400);
/// start of testing routine for correct driving using inverse logic, the external Relay. The Virtual Button SW V8 <==> GP5///
BLYNK_WRITE(V8)
digitalWrite(5, LOW);
/// end of testing routine for correct driving external inverse logic Relay using Virtual Button SW ///
/// start of rebootToConfig() routine for ISSUE reset to config to OAK if V3 button pressed for >= 3 seconds ///
BLYNK_WRITE(V3)
/// button pressed ///
lcd.clear(); //Use it to clear the LCD Widget;
lcd.print(0, 0, "Rebooting.....");
lcd.print(0, 1, "in WiFi Config!");
delay(400);
Oak.rebootToConfig();
/* THIS DOES NOT WORK AS EXPECTED
BLYNK_WRITE(V3)
currentMillis = millis();
/// button released ///
if (millis() - currentMillis > interval) {
/// do something after long button press.
delay(500);
void blinkLedWidget()
if (led1.getValue()) {
led1.off();
BLYNK_LOG("LED1: off");
led1.on();
BLYNK_LOG("LED1: on");
// Every time we connect to the cloud synchronize all the values from Widgets...
BLYNK_CONNECTED() {
/// if (isFirstConnect)
// Request Blynk server to re-send latest values for all pins
Blynk.syncAll();
if (digitalRead(5)== 1)
led2.on();
led2.off();
