I now have this error, please help me
Just throwing random snippets of code into your sketch wonβt work, as youβve discovered.
The BlynkTimer object needs to be declared with an appropriate name (βtimerβ in this case) and this object name needs to be called in your void loop for it to do anything.
This would look like this:
Iβd suggest that you take a step back and learn more about how SimpleTimer or itβs cousin BlynkTimer work and how to use them in your code. That way you will understand how to use timers correctly in your code and what the correct syntax and usage is.
