How to make BLYNK run my Parola Sketch using WeMosD1
With previous help from Arduino Forum, I ended up using the Arduino sketch below which works OK for me.
I use it to scroll messages from my iPhone “via WiFi” to my Max7219 (six 8x8) matrix
How do I add BLYNK to my sketch code so I can send messages from my iPhone “via the internet” instead of (or in addition to) WiFi ??
Conversely…if it’s easier or more proper, how would I add my sketch code to a BLYNK example or something.
Thank You
This code is a bit long (sorry, not my doing…as a newbie I was copying examples and editing as needed).
// file  wemos3_FINAL_SendSCROLLtext_via_iPhone_WiFi
//  from WEBSITE  https://www.youtube.com/watch?v=UA0qskH1CO8
// Use the MD_MAX72XX library to scroll text on the display
// RECEIVED VIA  the ESP8266 WiFi interface eg. WeMosD1
// Demonstrates the use of the callback function to control what
// is scrolled on the display text.
// User can enter text THROUGH A WEB BROWSER
// and this will display as a scrolling message on the display.
// IP address for the ESP8266 is displayed on the scrolling display
#include <MD_MAX72xx.h>
#define PRINT_CALLBACK  0
#define DEBUG 0
#define LED_HEARTBEAT 0
#if DEBUG
#define PRINT(s, v) { Serial.print(F(s)); Serial.print(v); }
#define PRINTS(s)   { Serial.print(F(s)); }
#else
#define PRINT(s, v)
#define PRINTS(s)
#endif
#if LED_HEARTBEAT
#define HB_LED  D2
#define HB_LED_TIME 500 // in milliseconds
#endif
// Define the number of devices we have in the chain and the hardware interface
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 6
#define CLK_PIN     D7
#define DATA_PIN  D6
#define CS_PIN       D5
// SPI hardware interface
MD_MAX72XX mx = MD_MAX72XX(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
// WiFi login parameters - network name and password
const char* ssid = "mySSID";
const char* password = "myPassword";
// WiFi Server object and parameters
WiFiServer server(80);
// Global message buffers shared by Wifi and Scrolling functions
const uint8_t MESG_SIZE = 255;
const uint8_t CHAR_SPACING = 1;
const uint8_t SCROLL_DELAY = 75;
char curMessage[MESG_SIZE];
char newMessage[MESG_SIZE];
bool newMessageAvailable = false;
const char WebResponse[] = "HTTP/1.1 200 OK\nContent-Type: text/html\n\n";
const char WebPage[] =
"<!DOCTYPE html>" \
"<html>" \
"<head>" \
"<title>MajicDesigns Test Page</title>" \
"<script>" \
"strLine = \"\";" \
"function SendText()" \
"  nocache = \"/&nocache=\" + Math.random() * 1000000;" \
"  var request = new XMLHttpRequest();" \
"  strLine = \"&MSG=\" + document.getElementById(\"txt_form\").Message.value;" \
"  request.open(\"GET\", strLine + nocache, false);" \
"  request.send(null);" \
"</script>" \
"</head>" \
"<body>" \
"<p><b>MD_MAX72xx set message</b></p>" \
"<form id=\"txt_form\" name=\"frmText\">" \
"<label>Msg:<input type=\"text\" name=\"Message\" maxlength=\"255\"></label><br><br>" \
"</form>" \
"<br>" \
"<input type=\"submit\" value=\"Send Text\" onclick=\"SendText()\">" \
"</body>" \
"</html>";
const char *err2Str(wl_status_t code)
  switch (code)
  case WL_IDLE_STATUS:    return("IDLE");           break; // WiFi is in process of changing between statuses
  case WL_NO_SSID_AVAIL:  return("NO_SSID_AVAIL");  break; // case configured SSID cannot be reached
  case WL_CONNECTED:      return("CONNECTED");      break; // successful connection is established
  case WL_CONNECT_FAILED: return("CONNECT_FAILED"); break; // password is incorrect
  case WL_DISCONNECTED:   return("CONNECT_FAILED"); break; // module is not configured in station mode
  default: return("??");
uint8_t htoi(char c)
  c = toupper(c);
  if ((c >= '0') && (c <= '9')) return(c - '0');
  if ((c >= 'A') && (c <= 'F')) return(c - 'A' + 0xa);
  return(0);
boolean getText(char *szMesg, char *psz, uint8_t len)
  boolean isValid = false;  // text received flag
  char *pStart, *pEnd;      // pointer to start and end of text
  // get pointer to the beginning of the text
  pStart = strstr(szMesg, "/&MSG=");
  if (pStart != NULL)
    pStart += 6;  // skip to start of data
    pEnd = strstr(pStart, "/&");
    if (pEnd != NULL)
      while (pStart != pEnd)
        if ((*pStart == '%') && isdigit(*(pStart+1)))
          // replace %xx hex code with the ASCII character
          char c = 0;
          pStart++;
          c += (htoi(*pStart++) << 4);
          c += htoi(*pStart++);
          *psz++ = c;
          *psz++ = *pStart++;
      *psz = '\0'; // terminate the string
      isValid = true;
  return(isValid);
void handleWiFi(void)
  static enum { S_IDLE, S_WAIT_CONN, S_READ, S_EXTRACT, S_RESPONSE, S_DISCONN } state = S_IDLE;
  static char szBuf[1024];
  static uint16_t idxBuf = 0;
  static WiFiClient client;
  static uint32_t timeStart;
  switch (state)
  case S_IDLE:   // initialize
    PRINTS("\nS_IDLE");
    idxBuf = 0;
    state = S_WAIT_CONN;
    break;
  case S_WAIT_CONN:   // waiting for connection
      client = server.available();
      if (!client) break;
      if (!client.connected()) break;
#if DEBUG
      char szTxt[20];
      sprintf(szTxt, "%03d:%03d:%03d:%03d", client.remoteIP()[0], client.remoteIP()[1], client.remoteIP()[2], client.remoteIP()[3]);
      PRINT("\nNew client @ ", szTxt);
#endif
      timeStart = millis();
      state = S_READ;
    break;
  case S_READ: // get the first line of data
    PRINTS("\nS_READ");
    while (client.available())
      char c = client.read();
      if ((c == '\r') || (c == '\n'))
        szBuf[idxBuf] = '\0';
        client.flush();
        PRINT("\nRecv: ", szBuf);
        state = S_EXTRACT;
        szBuf[idxBuf++] = (char)c;
    if (millis() - timeStart > 1000)
      PRINTS("\nWait timeout");
      state = S_DISCONN;
    break;
  case S_EXTRACT: // extract data
    PRINTS("\nS_EXTRACT");
    // Extract the string from the message if there is one
    newMessageAvailable = getText(szBuf, newMessage, MESG_SIZE);
    PRINT("\nNew Msg: ", newMessage);
    state = S_RESPONSE;
    break;
  case S_RESPONSE: // send the response to the client
    PRINTS("\nS_RESPONSE");
    // Return the response to the client (web page)
    client.print(WebResponse);
    client.print(WebPage);
    state = S_DISCONN;
    break;
  case S_DISCONN: // disconnect client
    PRINTS("\nS_DISCONN");
    client.flush();
    client.stop();
    state = S_IDLE;
    break;
  default:  state = S_IDLE;
void scrollDataSink(uint8_t dev, MD_MAX72XX::transformType_t t, uint8_t col)
// Callback function for data that is being scrolled off the display
#if PRINT_CALLBACK
  Serial.print("\n cb ");
  Serial.print(dev);
  Serial.print(' ');
  Serial.print(t);
  Serial.print(' ');
  Serial.println(col);
#endif
uint8_t scrollDataSource(uint8_t dev, MD_MAX72XX::transformType_t t)
// Callback function for data that is required for scrolling into the display
  static enum { S_IDLE, S_NEXT_CHAR, S_SHOW_CHAR, S_SHOW_SPACE } state = S_IDLE;
  static char *p;
  static uint16_t curLen, showLen;
  static uint8_t  cBuf[8];
  uint8_t colData = 0;
  // finite state machine to control what we do on the callback
  switch (state)
  case S_IDLE: // reset the message pointer and check for new message to load
    PRINTS("\nS_IDLE");
    p = curMessage;      // reset the pointer to start of message
    if (newMessageAvailable)  // there is a new message waiting
      strcpy(curMessage, newMessage); // copy it in
    state = S_NEXT_CHAR;
    break;
  case S_NEXT_CHAR: // Load the next character from the font table
    PRINTS("\nS_NEXT_CHAR");
    if (*p == '\0')
      state = S_IDLE;
      showLen = mx.getChar(*p++, sizeof(cBuf) / sizeof(cBuf[0]), cBuf);
      curLen = 0;
      state = S_SHOW_CHAR;
    break;
  case S_SHOW_CHAR: // display the next part of the character
    PRINTS("\nS_SHOW_CHAR");
    colData = cBuf[curLen++];
    if (curLen < showLen)
      break;
    // set up the inter character spacing
    showLen = (*p != '\0' ? CHAR_SPACING : (MAX_DEVICES*COL_SIZE)/2);
    curLen = 0;
    state = S_SHOW_SPACE;
    // fall through
  case S_SHOW_SPACE:  // display inter-character spacing (blank column)
    PRINT("\nS_ICSPACE: ", curLen);
    PRINT("/", showLen);
    curLen++;
    if (curLen == showLen)
    break;
  default:
    state = S_IDLE;
  return(colData);
void scrollText(void)
  static uint32_t	prevTime = 0;
  // Is it time to scroll the text?
  if (millis() - prevTime >= SCROLL_DELAY)
    mx.transform(MD_MAX72XX::TSL);  // scroll along - the callback will load all the data
    prevTime = millis();      // starting point for next time
#if DEBUG
  PRINTS("\n[MD_MAX72XX WiFi Message Display]\nType a message for the scrolling display from your internet browser");
#endif
#if LED_HEARTBEAT
  pinMode(HB_LED, OUTPUT);
  digitalWrite(HB_LED, LOW);
#endif
  // Display initialization
  mx.begin();
  mx.setShiftDataInCallback(scrollDataSource);
  mx.setShiftDataOutCallback(scrollDataSink);
  curMessage[0] = newMessage[0] = '\0';
  // Connect to and initialize WiFi network
  PRINT("\nConnecting to ", ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    PRINT("\n", err2Str(WiFi.status()));
    delay(500);
  PRINTS("\nWiFi connected");
  // Start the server
  server.begin();
  PRINTS("\nServer started");
  // Set up first message as the IP address
  sprintf(curMessage, "%03d:%03d:%03d:%03d", WiFi.localIP()[0], WiFi.localIP()[1], WiFi.localIP()[2], WiFi.localIP()[3]);
  PRINT("\nAssigned IP ", curMessage);
#if LED_HEARTBEAT
  static uint32_t timeLast = 0;
  if (millis() - timeLast >= HB_LED_TIME)
    digitalWrite(HB_LED, digitalRead(HB_LED) == LOW ? HIGH : LOW);
    timeLast = millis();
#endif
  handleWiFi();
  scrollText();
Sorry mate. No one will write the code for you .
Do some research. Learn how to add blynk to your code.
There are documentation on how it works on blynk official website.
Later when you have added blynk bit to your code and.still have problems, you can seek help here.
This is a very basic sketch ( empty sketch )
You can add your code to it.
Basic outline…
Blynk app or web console with a text input widget (you’d need to check if this is available with your current subscription).
Text input widget is connected to a virtual datastream of type String.
When you type your text into the widget and hit “Send” the BLYNK_WRITE(vPin) handler in your sketch will be triggered. You can then capture the text that was sent to a variable using variable = param.asString()
The rest of you sketch will consist of the standard code needed to connect your device to Blynk, and the code needed to scroll the received text on your display.
The problem you’ll have is that your current sketch has no in-code comments that act as documentation, and it used char variable types rather than String variable types.
If you understand the code then the lack of documentation isn’t an issue, but I guess that isn’t the case.
I find it much easier to work with strings rather than char variables, but in this case the char variable type may be more appropriate. Either way, once you’ve converted the string to a char array then the scrolling code will be pretty similar.
