How to know the time with Blynk?
Is there a way to fetch the current time and send it to an Arduino for instance using a bluetooth connection?
See
RTC Widget DOCS
and
RTC Sketch Example
Do make sure to set your correct hardware and connection type with the example sketch, and that you have all necessary libraries.
@Toro_Blanco I believe RTC requires internet connection on the device sideā€¦ something not available with BT/BLE
@lesept I suspect you will need to resort to a physical RTC module on the Arduino itself.
