How to get the correct country blynk IP address??
I live in Malaysia. I did tried many IP such as IP behind the router , and many recommend IP in forum here. But those IP doesn’t work. I use google assistant then use webhooks.
Below are the imformation fill in the webhooks:
URL:http://IP/token/update/PIN
Method : Put
Content Type : application/json
Body : [“1”]
Ping blynk-cloud.com and it will return the IP address of your nearest Blynk server. If you don’t know how to do a Ping then Google is your new best friend.
Thanks PeteKnight.
I ping blynk-cloud.com using window command promt. I get the ip . I will try this ip when i m free and share the result. Thanks again…
Hi PeteKnight,
My applet information is completed. But i tried voice conmand via google,there have no respond, and i notice that my applet “Never Run”. Do u know what’s wrong is it??
I don’t use IFTTT or Google Home, so I’m afraid not.
However, there are lots of guides on this forum to getting it working, so just do a bit of searching.
