define BLYNK_PRINT Serial
long randomNumber;
char auth[] = "MYCHAR";
char ssid[] = "MYNET";
char pass[] = "MYPASS";
void tweetUptime()
long uptime = millis() / 60000L;
Serial.println("Tweeting every 10 minutes ;)");
// Actually send the message.
// Note:
// We allow 1 tweet per 15 seconds for now.
// Twitter doesn't allow identical subsequent messages.
Blynk.tweet(String("been up high for ") + uptime + " minutes.");
void TweetwhenHIGH()
// Invert state, since button is "Active LOW"
//int isButtonPressed = !digitalRead(2);
//if (isButtonPressed) {
if (digitalRead(2) == HIGH) {
timer.setInterval(500L, TweetwhenHIGH);
Serial.println("Button is pressed.");
randomNumber = random(300);
Blynk.tweet(String("Testing ") + randomNumber + " HIGH");
Blynk.tweet(" Pin Went from Low to HIGH, doing tweet");
// Tweet immediately on startup
Blynk.tweet("My Arduino project is tweeting again");
// Reading analogRead to create a random Number
randomSeed(analogRead(0));
// Setup a function to be called every 2 minutes
timer.setInterval(2L * 60000L, tweetUptime);
// Setup twitter button on pin 2
pinMode(2, INPUT_PULLUP);
// Attach pin 2 interrupt to our handler
//attachInterrupt(digitalPinToInterrupt(2), tweetOnButtonPress, CHANGE);
