You can post the whole sketch after including the timer so we can take a look at it.
ok i will try and tell you .
thank you now my servo delay becuse of you and Mr.Pete
my wrong i was use
i should use
first i put
under the
#include "BlynkEdgent.h"
like this :
then i write this to delay the servo:
timer.setTimeout(10000L, [](){ //to delay the servo for 10sec
myservo.write(0); //the servo goes to angle 0
I have another question, can I make the servo unstable when no signal is given to it?
For example, when it is in a state of sleep, can it be moved manually?
Do you mean servo.detach() function ?
Yes i was try it now and i will tell you if itβs work with me
thanks broππ»
