HOW to control Virtual pins using IFTTT
details :
• nodeMCU-12E with WIFI. For example: Arduino UNO with Ethernet Shield
• Smartphone OS Android
• Blynk server(http://188.166.206.43/AUTH)
char auth[] = "WpY6CTvZ_--AUTH......";
char ssid[] = "MARKETING";
char pass[] = "hp111414243";
BLYNK_WRITE(V0)
  pinMode(0,OUTPUT);
  pinMode(2,OUTPUT);
  pinMode(12,OUTPUT);
  pinMode(14,OUTPUT);
  // You can also use:
  // String i = param.asStr();
  // double d = param.asDouble();
    digitalWrite(0,pinValue);
    digitalWrite(2,pinValue);
    digitalWrite(12,pinValue);
    digitalWrite(14,pinValue);
  Serial.println(pinValue);
Im using this code in my arduino the code works fine with app when i click the virtual button but when i use voice commands to control virtual pins nothing happen(voice commands are working with digital pins)
for webhooks the setting is as follows
http://188.166.206.43/AUTH/update/V0?value=1
Method:PUT
content type:application/json
Body:[“1”] even tried blank
i have even tried the get method but nothing happens
You’re using the GET syntax with the PUT method.
Strange as it seems, you should use GET for everything, so simply change the method to GET.
The Body field should always be blank.
Your IFTTT command will only set the pins HIGH (1), so to see the change the pins already need to be set to LOW (0) by the switch widget in the app.
Also, your pinMode statements only need to run once. so should be in the void setup and the libraries used in the clde don’t seem compatible with your stated hardware (Uno plus Ethernet shield).
