/please give me a best solution in easiest way. My arduino program is as below which is to be controlled by bluetooth HC06/
[Unformatted code removed bu moderator]
@sf2020, yet again you have posted code without triple backticks.
This time I’ve removed the code, as you should know better by now.
Please edit the post to add your code back in, with the necessary backticks, and please use triple backticks every time you post code in future, otherwise your posts will simply be deleted.
