• Hardware model: Arduino WEMOS D1 R2
• Smartphone OS version: Android 9
• Blynk server
• Blynk Library version : 0.5.0
The Blynk APP can continuously update temperature and humidity when updating data every ten seconds
delay(10000); //Upload data time
The BLYNK APP cannot continuously update the temperature and humidity and only displays the first data when updating the data every minute
delay(60000); //Upload data time
So how do I update the temperature and humidity to the BLYNK APP every minute?
Many Thanks!
//APP Blynk
#include "DHT.h" // dht22
#include <ArduinoJson.h>
//*-- Hardware Serial
#define _baudrate 9600
//*-- dht22
#define _dhtpin 2 //according to pin define D4
#define _dhttype DHT22 //Select sensor type
// Initialize DHT sensor
DHT dht22( _dhtpin, _dhttype );
float temperature, humidity;
//*-- IoT Information
#define SSID "D-Link_DIR-612_Irving" //your AP ssid
#define PASS "0939953008" //your AP password
#define HOST "api.thingspeak.com" // ThingSpeak IP Address: 184.106.153.149
#define PORT 80
#define READAPIKEY "x" // READ APIKEY for the CHANNEL_ID
// GET /update?key=[THINGSPEAK_KEY]&field1=[data 1]&filed2=[data 2]...;
String GET = "GET /update?key=x";
//Blynk Information
char ssid[] = "D-Link_DIR-612_Irving";
char pass[] = "0939953008";
char auth[] = "x"; //Blynk Verification code
Serial.begin( _baudrate );
Serial.println( "ESP8266 Ready!" );
Serial.println( "Sample01" ); //sample01
// Connecting to a WiFi network
Serial.print("Connect to ");
Serial.println( SSID );
WiFi.begin( SSID, PASS );
//setup blynk
Serial.println( "Blynk Ready!" );
while( WiFi.status() != WL_CONNECTED )
delay(500);
Serial.print( "." );
Serial.println( "" );
Serial.println( "WiFi connected" );
Serial.println( "IP address: " );
Serial.println( WiFi.localIP() );
// dht22
dht22.begin();
Serial.println( "DHT22 Ready!" );
delay(2000);
timer.setInterval( 1000L, upblynk );
void upblynk()
humidity = dht22.readHumidity();
temperature = dht22.readTemperature();
if( isnan( humidity ) || isnan( temperature ) )
Serial.println( "sample01 Failed to read form dht22" );
WiFiClient client;
if( !client.connect("maker.ifttt.com",80 ) )
Serial.println( "fail" );
return;
String getStr_line = "GET /trigger/test/with/key/csF5wehrx8iqKJu1HnsBrL?value1=sample01Failed HTTP/1.1\r\n";
client.print( getStr_line );
client.print( "Host: maker.ifttt.com\n" );
client.print( "Connection: close\r\n\r\n" );
client.stop();
delay(10000);
return;
Serial.print( "sample01Humidity: " );
Serial.print( humidity );
Serial.print( "sample01Temperature: " );
Serial.println( temperature );
updatedht22();
void updatedht22()
Blynk.virtualWrite(V0, temperature);
Blynk.virtualWrite(V1, humidity );
WiFiClient client;
if( !client.connect( HOST, PORT ) )
Serial.println( "connection failed" );
return;
String getStr = GET + "&field1=" + String((int)temperature) +
"&field2=" + String((int)humidity) +
" HTTP/1.1\r\n";;
client.print( getStr );
client.print( "Host: api.thingspeak.com\n" );
Serial.println( "Thingspeak PASS" );
client.stop();
