How to configure (connection to) my own blynk server?
#1
Thank you, how to configure my own blynk server? I tried it many times, I failed, what should I do?
*WM: Request redirected to captive portal
*WM: WiFi save
*WM: Parameter
*WM: server
*WM: 207.148.73.**
*WM: Parameter
*WM: port
*WM: 8080
*WM: Parameter
*WM: blynk
*WM: a980064ea6bd4b6084114c4dcf09****
*WM: Sent wifi save page
*WM: Connecting to new AP
*WM: Connecting as wifi client...
*WM: Connection result:
*WM: 3
Should save config
connected...yeey :)
saving config
{"mqtt_server":"207.148.**.**","mqtt_port":"8080","blynk_token":"a9****4ea6bd4b6084114c4dcf09****"}BLYNK Connection Fail
a980064ea6bd4b6084114c4dcf09876c
*WM: settings invalidated
*WM: THIS MAY CAUSE AP NOT TO START UP PROPERLY. YOU NEED TO COMMENT IT OUT AFTER ERASING THE DATA.
 ets Jan  8 2013,rst cause:2, boot mode:(1,6)
 ets Jan  8 2013,rst cause:4, boot mode:(1,6)
wdt reset
How can I save an auth token input with Wi-Fi Manager?
#2
Hello. Instead of you tagging onto another older and solved topic about a different issue from your apparent request… I moved your post into its own topic.
Now please supply full details of what you are wanting to do , what you have trying and the results… Preferably something that means something to your question instead of whatever you posted, :stuck_out_tongue_winking_eye:
#3
#include <FS.h>                   //this needs to be first, or it all crashes and burns...
#include <ESP8266WiFi.h>          //https://github.com/esp8266/Arduino
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>          //https://github.com/tzapu/WiFiManager
#include <ArduinoJson.h>          //https://github.com/bblanchon/ArduinoJson
//#define BLYNK_DEBUG
//define your default values here, if there are different values in config.json, they are overwritten.
char mqtt_server[40];
char mqtt_port[6] = "8080";
char blynk_token[34] = "a980064ea6bd4b6084114c4dcf09876c";
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying us of the need to save config
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
  Serial.println();
  //clean FS, for testing
  SPIFFS.format();
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(mqtt_server, json["mqtt_server"]);
          strcpy(mqtt_port, json["mqtt_port"]);
          strcpy(blynk_token, json["blynk_token"]);
          Serial.println("failed to load json config");
        configFile.close();
    Serial.println("failed to mount FS");
  //end read
  // The extra parameters to be configured (can be either global or just in the setup)
  // After connecting, parameter.getValue() will get you the configured value
  // id/name placeholder/prompt default length
  WiFiManagerParameter custom_mqtt_server("server", "mqtt server", mqtt_server, 40);
  WiFiManagerParameter custom_mqtt_port("port", "mqtt port", mqtt_port, 6);
  WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 32);
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  //set config save notify callback
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  //set static ip
  wifiManager.setSTAStaticIPConfig(IPAddress(10,0,1,99), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
  //add all your parameters here
  wifiManager.addParameter(&custom_mqtt_server);
  wifiManager.addParameter(&custom_mqtt_port);
  wifiManager.addParameter(&custom_blynk_token);
  //reset settings - for testing
 wifiManager.resetSettings();
  //set minimu quality of signal so it ignores AP's under that quality
  //defaults to 8%
  //wifiManager.setMinimumSignalQuality();
  //sets timeout until configuration portal gets turned off
  //useful to make it all retry or go to sleep
  //in seconds
  //wifiManager.setTimeout(120);
  //fetches ssid and pass and tries to connect
  //if it does not connect it starts an access point with the specified name
  //here  "AutoConnectAP"
  //and goes into a blocking loop awaiting configuration
  if (!wifiManager.autoConnect("AutoConnectAP", "password")) {
    Serial.println("failed to connect and hit timeout");
    delay(3000);
    //reset and try again, or maybe put it to deep sleep
    ESP.reset();
    delay(5000);
  //if you get here you have connected to the WiFi
  Serial.println("connected...yeey :)");
  //read updated parameters
  strcpy(mqtt_server, custom_mqtt_server.getValue());
  strcpy(mqtt_port, custom_mqtt_port.getValue());
  strcpy(blynk_token, custom_blynk_token.getValue());
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    json["mqtt_server"] = mqtt_server;
    json["mqtt_port"] = mqtt_port;
    json["blynk_token"] = blynk_token;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.printTo(configFile);
    configFile.close();
    //end save
  Serial.println("local ip");
  Blynk.config(blynk_token);
  bool result = Blynk.connect();
if (result != true)
  Serial.println("BLYNK Connection Fail");
  Serial.println(blynk_token);
  ESP.reset();
  delay (5000);
  Serial.println("BLYNK Connected");
  // put your main code here, to run repeatedly:
*WM: Handle root
*WM: Handle root
*WM: WiFi save
*WM: Parameter
*WM: server
*WM: 207.148.73.56
*WM: Parameter
*WM: port
*WM: 8080
*WM: Parameter
*WM: blynk
*WM: a980064ea6bd4b6084114c4dcf09876c
*WM: static ip
*WM: 10.0.1.99
*WM: static gateway
*WM: 10.0.1.1
*WM: static netmask
*WM: 255.255.255.0
*WM: Custom STA IP/GW/Subnet
*WM: 10.0.1.99
*WM: Already connected. Bailing out.
Should save config
connected...yeey :)
saving config
{"mqtt_server":"207.148.73.56","mqtt_port":"8080","blynk_token":"a980064ea6bd4b6084114c4dcf09876c"}local ip
10.0.1.99
 ets Jan  8 2013,rst cause:2, boot mode:(1,7)
 ets Jan  8 2013,rst cause:4, boot mode:(1,7)
wdt reset
#4
If i use my own server, I don’t know how to modify it, please help me.
#5
It seems that you also don’t know how to format your code correctly when posting on this forum!
@shuaiqi As per the Welcome Topic, I have properly formatted your posts for forum viewing. Please look at how to do this properly yourself.
As for your issue, are you saying you are just copying someone else’s code and this is NOT your IPs?
#7
There’s certainly a Blynk server with a project using that auth code at the external server IP address. If it’s not @shuaiqi’s server then he’s just shared someone else’s details on a public forum!
#8
thank you
#11
Nope… it stays, as a hopeful reference for others that dutifully search and read :rofl: before asking lots of questions
#12
Ok, thank you very much.
