In the old legacy app you had the option to choose what virtual pin index to whatever you wanted it to be. For instance I could choose V5 for a button.
Now the virtual pins you can use seems to be limited to the data type you want to use. Each button I add is assigned V0 for instance. Obviously this is a problem.
Can this be fixed/changed?
