I’m struggeling to understand what you need help with?
You are posting different codes. You were on the right path with post #17, then you went bananaz and posted another piece of code which is entirely different
Reason why your code in post #17 did not work is due to syntax errors from what I can see.
As I mentioned earlier, there was the double paranthesis but now I also notice you have a missing bracket.
#include <Blynk.h>
int timerID =1;
int notifyUptime;
BLYNK_WRITE(V0){ // add a slider on V0 range 0 to 30 (minutes)
int seconds = param.asInt();
Serial.println(seconds);
timer.deleteTimer(timerID);
timerID = timer.setInterval(seconds * 10000L, notifyUptime);
Serial.print("V0 Slider value is: ");
Serial.print("CountdownValue will be: ");
} //<--- MISSING EARLIER
timerID = timer.setInterval(10000L, notifyUptime); //<--- EXTRA PARANTHESIS EARLIER
Try it out. And next time do me a favour, before you post your code make sure you catch theese minor errors yourself, its not fun spending my time debugging at this level and I will refrain from helping unless I am extreeeeeeeeeeemly bored if I notice that errors are at this level.
