How to add if else statement in this code (like i want to turn on my motor if water level is low)
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
#define BLYNK_TEMPLATE_ID "TMPL4yb3N5Is"
#define BLYNK_DEVICE_NAME "WaterAmit"
#define BLYNK_PRINT SwSerial
char auth[] =
WidgetLCD lcd(V1);
long duration, distance;
int trig =4;
int eco = 5;
int temp=0;
void myTimerEvent()
  int data = analogRead(A2)*(3.20/1023.0)*100.0;
  Blynk.virtualWrite(V5, data);
BLYNK_WRITE(V2)
  int pinValue = param.asInt();
  digitalWrite(2, pinValue);
  digitalWrite(3, pinValue);
  SwSerial.begin(9600);
  Blynk.begin(Serial, auth);
  pinMode(trig, OUTPUT);
  pinMode(eco, INPUT);
  lcd.clear();
  lcd.print(0, 0, "Water Level");
  lcd.clear();
  digitalWrite(trig, LOW);
  delayMicroseconds(3);
  digitalWrite(trig, HIGH);
  delayMicroseconds(10);
  digitalWrite(trig,LOW);
  duration = pulseIn(eco, HIGH);
  distance = (duration/2) /322;
  lcd.print(7,1, distance);
First of all, you must read this
https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
