How frequent are the Eventor events checked?
Eventor is great,
But I did not find the information on how often the events programmed in the eventor are checked.
@jacquesBBB Eventor currently has many limitations and you might want to consider OTA updates as an alternative.
From the docs:
NOTE : Events are triggered only once when the condition is met. However there is one exclusion: Let’s consider simple event as above if (temperature > 40) send notification. When temperature goes beyond 40 threshold - notification action is triggered. If temperature continues to stay above the 40 threshold no actions will be triggered. But if temperature goes below threshold and then passes it again - notification will be sent again (there is no 15 sec limit on Eventor notifications).
In addition to @Costas answer - as soon as they arrive.
OK,
I understand now. So I need in fact to send back the information to the
hardware in order to use it repeatedly.
