Hi:
I face a problem that minute records on Blynk local server are erased after a period of time
Did the research and found that it might be solved by using db.properties
So if I want to keep all of the minute records, the only thing I need is a file named db.properties containing only a clause “clean.reporting=false” in it and put this file in the same folder as where server.properties stays, is that correct?
Or I have to deal with other db properties?
