How difficult/easy is this? And if it's possible could I have a hand?
I’d like to use Blynk to basically give me a push button on my iPhone that I can use to fire off a “Particle Publish” from my Particle Photon. I gather this can’t be done directly but would have to be done via a virtual pin? After that…I’m a bit lost.
Thanks!!
@boomdom I’ve not used a particle board and presume “Particle Publish” is a firmware routine available on the Particle board.
In Blynk app, you define a button attached to virtual pin V1. In your sketch, create a function BLYNK_WRITE(V1) to invoke publish. Am giving an example code snippet below:
BLYNK_WRITE(V1)
  digitalWrite(sw1, pinValue);
  stat_sw1 = pinValue;
  Serial.print("\nApp button change. V1 is set to ");
  Serial.println(pinValue);
When you press the button in the app, this routine will get executed. Trust this helps.
Sounds very doable! Thank you! :slight_smile:
Final (hopefully) question @mohan_sundaram, it says in the guidance to keep the loop to just two lines - does this mean I have to completely refactor any existing Particle Photon code before I can integrate with Blynk? And remove stuff out of loop and into functions?
Yes. Loop should be as clear as possible. Also, use Timer library available in Particle IDE
