How can i solve the problem of esp8266 not respond
⸮[9]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v0.5.3 on Arduino Uno
Give Blynk a Github star! => https://github.com/blynkkk/blynk-library
[523] Connecting to Eluga ray x
AT
[1533] ESP is not responding
AT+CIPCLOSE=1
AT+CIPCLOSE=1
AT+CIPSTART=1,“TCP”,“blynk-cloud.com”,80
AT+CIPCLOSE=1
now i am using arduino uno and esp8266 when i am trying connect the blynk this type of error will appear an my serial monitor how to solve the problem
Start by posting your code - correctly formatted using backticks and cpp.
#include <ESP8266_Lib.h>
char auth[] = "";
char ssid[] = "Eluga ray x";
char pass[] = "12345678";
#define EspSerial Serial
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
WidgetLED led1(V1);
// V1 LED Widget is blinking
void blinkLedWidget()
  if (led1.getValue()) {
    led1.off();
    Serial.println("LED on V1: off");
    led1.on();
    Serial.println("LED on V1: on");
  pinMode(13,OUTPUT);
  // Set ESP8266 baud rate
  Blynk.begin(auth, wifi,ssid,pass,"blynk-cloud.com", 8442);
  //Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
  //Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
hey bro this is my code i am trying to solve this problem in last 1 week but i can not solve plz help to solve
Well, if you’re using an Uno then you should be following these instructions and using software serial…
You wouldn’t want your software serial baud rate to be more than 9600, and your ESP needs to have been configured to use the same baud rate using an AT command.
If you do a bit of searching on this forum for Uno, ESP8266 and Software serial you’ll find all the answers you need.
Youu have not setup the software serial ports and your BAUD rate is too high, should be 9600… and the ESP needs to be programmed for same BAUD rate
As instructed… You need to search this forum for one or all of the dozens of topics about this ESP as shield issue and the already posted solutions.
sorunu çözebildinizmi?Aynı sorun bendede var.Yardımcı olabilirmisiniz?Bir türlü wifiye bağlanmıyor.Programa bağlanmıyor.Yardım lütfen
