How can i send range value for pin without creating slider widget in the project
I want to send value for pin as a range using rest api. If i add a slider in the project and when i try to put value for pin it works but if i dont have a slider in project no matter what i write it always reads it as 0 or 1.
Did you set the output to 0 - 1023 like the slider?
Local server or Cloud server?
Cloud server
Yes I did,
Is it set to a digital pin or a v pin?
Digital
I tried it with a v pin and it worked for me. Is there a need for it to be on the hardware pin?
