Hi everyone!
I’m using the Blynk App, a ESP32 dev module board, 3 LED’s and a push button (and resistors of course). What I want to do is to send commands to the ESP32 using the Blynk App and BLE. That means that with the Blynk App I send a sequence to the ESP32, for example:
- First the blue LED goes ON
- When the physical push button is pressed the red LED goes ON.
- When the physical push button is pressed again the green LED goes ON.
Is there any possibility that I can send this information to the ESP32 using the Blynk App (without having to implement new code if I want to change the sequence), and that it remembers even when the BLE connection is lost? (so the commands are storaged in the ESP32).
Thank you very much!
