Hello, I am using blynk and have 3 projects.
In the Blynk GUI I have the most used project as the second one in menu.
Is there a chance or opportunity to change the orders of the 3 projects so I do not must slider each time to the second.and the second become on the first position? Greetings Rainer
No, although if you are using a local Blynk server and are feeling brave then you may be able to edit the user file to change the sequence.
