I want that the BLYNK_WRITE function will run in a loop?
Can somebody tell me, how can I do this?
I don’t mean that it only will run when I move the slider.
It should run in a loop.
Thanks for help.
Here is the code:
#include "DHT.h"
#define DHTPIN 0 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
int Thermostat = 16;
char auth[] = "xxxxxxxxx";
char ssid[] = "xxxxxxxxx";
char pass[] = "xxxxxxxxxxxxx";
DHT dht(DHTPIN, DHTTYPE);
// in Blynk app writes values to the Virtual Pin 1
BLYNK_WRITE(V1)
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
Serial.print("V1 Slider value is: ");
Serial.println(pinValue);
float h = dht.readHumidity(); // Lesen der Luftfeuchtigkeit und speichern in die Variable h
float t = dht.readTemperature(); // Lesen der Temperatur in °C und speichern in die Variable t
/*********************( Überprüfen ob alles richtig Ausgelesen wurde )*********************/
if (isnan(h) || isnan(t)) {
Serial.println("Fehler beim auslesen des Sensors!");
return;
// Nun senden wir die gemessenen Werte an den PC dise werden wir im Seriellem Monitor sehen
Serial.print("Luftfeuchtigkeit: ");
Serial.print(h); // Ausgeben der Luftfeuchtigkeit
Serial.print("%\t"); // Tabulator
Serial.print("Temperatur: ");
Serial.print(t); // Ausgeben der Temperatur
Serial.write('°'); // Schreiben des ° Zeichen
Serial.println("C");
if (t > pinValue)
digitalWrite(Thermostat, LOW);
digitalWrite(Thermostat, HIGH);
void sendSensor()
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
dht.begin();
pinMode(Thermostat, OUTPUT);
I think you will have it easy then, blynk_write IS in a loop.
to be exact, here:
I don’t know the details but during blynk run all the ‘channels’ and pins are checked for updates. This is when the write function is called IF that pin has changed.
I’m guessing however you want to have it run regardless of the ‘IF’ in that case do NOT put it in there. Create a separate function which you put on a timer (you do NOT want to have sensor readout a few 1000 times per second) and you can also call this function in the ‘write’ function. http://docs.blynk.cc/#blynk-firmware-blynktimer
So you mean that I put a function inside that:
BLYNK_WRITE(V1)
Serial.print("V1 Slider value is: ");Preformatted text
return;
if (t > pinValue)
i don’t know how to do that but you could just store the value recieved in the form of param.asInt() in a global integer and then create a void Function that does what your BLYNK_WRITE does and then you can just call that funtion using BlynkTImer again and again.
@PsuchBLYNK_WRITE(vPin) is a function (AKA handler) that gets called whenever the associated vPin state/value changes. You can run code inside this function just like any other Arduino function.
To call this function from within the script itself, you simply use Blynk.virtualWrite(vPin, data) to send the required state/value change to the associated widget (this step is optional), followed by a Blynk.syncVirtual(vPin) to emulate the widget calling the function and requesting the Server to refresh that function with whatever was the last vPin state/value…
@Wahyudi if you’ve read the rest of this topic, you should understand that BLYNK_WRITE(vPin) is a special callback function which is called whenever the value of the corresponding virtual pin changes on the Blynk server.
It is triggered once, automatically, and cannot be called as part of a loop function.
If, once the value of the virtual pin changes on the server, you want to run a process multiple times then you need to use the BLYNK_WRITE(vPin) to initialise a timer or to set a flag so that a process which is already running via a timer behaves differently when the state of the flag is tested.
I’m going to close this 2-year old topic. If you have a specific issue that isn’t answered by this topic then I’d suggest that you start a new topic and provide all of the necessary information to allow is to understand the hardware and software that you are using, and exactly what the issue you are experiencing is.
