How can i make an if conditions on 2 devices then do something?
I have 2 units on water tanks and a relay with a pump connected to 1 of the units. is there a way to make it do if tank percentage is greater than a set value on tank1 and percentage is lower than set value on the tank2 then trigger the relay on tank 1 board? but if conditions not met then do nothing?
if so then how please? this is my sketch so far that i put on both boards and just change the char auth when altering anything as have had no reason for the images to be any different as of yet.
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example runs directly on ESP8266 chip.
  Please be sure to select the right ESP8266 module
  in the Tools -> Board menu!
  Feel free to apply it to any other example. It's simple!-
#include <ESP8266mDNS.h>  // For OTA w/ ESP8266
#include <WiFiUdp.h>  // For OTA
#include <ArduinoOTA.h>  // For OTA
// char auth[] = "oiXdJdY-cmz1WbZfr7o1SdUgncXJBCQF";// House Tank
char auth[] = "x3HDpMHpx8odgd2aKsSSR-d_TeYxWWjR";// Garage Tank
// char ssid[] = "Idamo"; // House Tank
char ssid[] = "Idamo Garage"; // Garage Tank
char pass[] = "gareth10";
int port = 8080;
// defines pins numbers
// trigpin on board is d14, echo is d15
const int trigPin = 4;
const int echoPin = 5;
int relayPin = 13;// define output pin for relay (13 = MOSI)
// defines variables
BlynkTimer timer; // Announcing the timer
long duration;
float sheight;
float capacity;
float height;
float pumptime;
float distance;
float percentageFull;
float finalPercentage;
float finalcapacity;
  Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,84), 8080);
  pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
  pinMode(echoPin, INPUT); // Sets the echoPin as an Inputs
  pinMode(relayPin, OUTPUT); // Sets the relayPin as an Output
  digitalWrite(relayPin, HIGH); // Sets relayPin to HIGH
  timer.setInterval(15000L, sensorDataSend); //timer will run every sec (changed 500 1/2 a sec to 15000 15 secs)
//  ArduinoOTA.setHostname("House Tank");
  ArduinoOTA.setHostname("Garage Tank");
  ArduinoOTA.begin();  // For OTA
BLYNK_CONNECTED()
  Blynk.syncVirtual(V4);
  Blynk.syncVirtual(V5);
  Blynk.syncVirtual(V6);
  Blynk.syncVirtual(V7);
void sensorDataSend()
digitalWrite(trigPin, LOW);
delayMicroseconds(5);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
// Calculating the distance
distance= duration*0.034/2;
distance= distance-sheight;
percentageFull=(distance/height);
finalPercentage=(1-percentageFull)*100;
finalcapacity= (1-percentageFull)*(capacity*100);
/* Prints the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.println(distance);
Serial.print("percentagefull: ");
Serial.println(percentageFull);
Serial.print("finalPercentage: ");
Serial.println(finalPercentage);
Serial.print("finalcapacity: ");
Serial.println(finalcapacity);
//delay(5000);
Blynk.virtualWrite(V0, finalPercentage);
Blynk.virtualWrite(V1, finalcapacity);
// distance= 0;
// percentageFull= 0;
// finalPercentage= 0;
// finalcapacity= 0;
BLYNK_WRITE(V2)  // Virtual button on Vx to activate action
  int pinvalue = param.asInt();
  int buttonState = param.asInt();
     if (pinvalue == 1) {
     digitalWrite(relayPin, LOW);  // Set pin low
     Blynk.virtualWrite(V2, 1);
     timer.setTimeout((pumptime*60000L), relayOFF);  // Run ActionOFF function in 5 seconds
     if (pinvalue == 0) {
     digitalWrite(relayPin, HIGH);  // Set pin high
     Blynk.virtualWrite(V2, 0);
void relayOFF()
BLYNK_WRITE(V3) // Reset
if (param.asInt()==1) {
delay(3000);
ESP.reset();
delay(5000);
BLYNK_WRITE(V4) //input from Numeric Widget for time pump runs
  pumptime = param.asInt();                            // Assigning incoming value from pin V4 to variable
  Blynk.virtualWrite(V14, pumptime);                   // V14 just to test it's working
  Serial.println(pumptime);
BLYNK_WRITE(V5) //input from Numeric Widget for height of sensor above max water level
  sheight = param.asInt();                            // Assigning incoming value from pin V5 to variable
  Blynk.virtualWrite(V11, sheight);                   // V11 just to test it's working
  Serial.println(sheight);
BLYNK_WRITE(V6) //input from Numeric Widget for max capacity of tank in L
  capacity = param.asInt();                            // Assigning incoming value from pin V6 to variable
  Blynk.virtualWrite(V12, capacity);                   // V12 just to test it's working
  Serial.println(capacity);
BLYNK_WRITE(V7) //input from Numeric Widget for height of water from bottom of tank to max water level
  height = param.asInt();                            // Assigning incoming value from pin V7 to variable
  Blynk.virtualWrite(V13, height);                   // V13 just to test it's working
  Serial.println(height);
BLYNK_WRITE(V99)  // Virtual button on Vx to activate action
  Blynk.run();        // run Blynk magic
  timer.run();        // run timer every second
  ArduinoOTA.handle();  // For OTA
Why yes! With enough skill in C++ you could land a space ship in the moon! (I guess) However that skill isn’t gained in 1 day or 1 sketch.
There is a relay off function in your code that appears to be called one time. A good practice would be to use it everywhere and have a corresponding relayOn function. If that’s to difficult right now use the digitalWrite HIGH/LOW commands.
In your question I believe you are talking about communicating between two boards. You can do this via Blynk bridge or another option is ESPnow but first I think you need to figure out a basic if, else if, else statement which is the very base of computer logic. So create a pumpONOFF function called every second that tests your percentage and triggers a relay HIGH or LOW. Your relay may be active high or active low. Let us know how that works.
