How can I loop an led animation code?
Hello
I am developing a project with an RGB led and the esp8266. when I press a button on the blynk app witch is connected to virtual pin 0 the led changes color according to the code but the code runs only when I press the button, I want it to loop continuously how can I change the code
Thank you in advance
#define GREEN 2
#define BLUE 5
#define RED 4
#define delayTime 1000
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
  Blynk.begin(auth, "xxxxx", "xxxxxx");
  pinMode(GREEN, OUTPUT);
  pinMode(BLUE, OUTPUT);
  pinMode(RED, OUTPUT);
  digitalWrite(GREEN, LOW);
  digitalWrite(BLUE, LOW);
  digitalWrite(RED, LOW);
BLYNK_WRITE(0)
 int i=param.asInt();
 if (i==1)
    digitalWrite(RED, HIGH);
    delay(delayTime);
    delay(delayTime);
    digitalWrite(GREEN, HIGH);
    delay(delayTime);
    delay(delayTime);
    digitalWrite(BLUE, HIGH);
    delay(delayTime);
    delay(delayTime);
Hello
instead of doing the animation on the button press. Make the button change the mode and in the loop depening on the current mode do the animation
#define GREEN 2
#define BLUE 5
#define RED 4
int mode ;
  mode = 0 ; // Start in a known state
BLYNK_WRITE(0)
 // Change state on button press
 if( param.asInt() == 1 ) {
  mode = 1 ;
  mode = 0 ;
  switch( mode ) {
    case 1:
      runModeOne();
      break;
    defaul: {
      // Do nothing
void runModeOne() {
  delay(delayTime);
  delay(delayTime);
  delay(delayTime);
  delay(delayTime);
  delay(delayTime);
  delay(delayTime);
I have tried the code but it is giving me an error runModeOne was not declared in the scope
You can move the loop function to the end.
