I’m looking for a service/feature that allows me to log events online. Similar to Thingspeak, but it should support text like the following and work together with Blynk.
“2018-09-05 8:33 AM Door Opened”
“2018-09-05 8:35 AM Door Closed”
“2018-09-05 10:35 AM Water Alarm Triggered”
I know the terminal feature of Blynk can be used for this. The issue is that it only saves the last 25 lines and I want to avoid a local Blynk server. I’m currently thinking of doing this by sending me an email for every event, but I would appreciate if there were a better way to do this.
The Table widget allows 100 rows to be stored if that helps.
Otherwise you can write the data to a Google spreadsheet or service like io.adafruit.com which gives up to 30 data points per minute and 30 days of storage for free.
Thank you, Pete and Dimitriy. A Google Spreadsheet would be sufficient for my purpose, but I haven’t found working instructions on how to implement that with Blnyk on an Arduino Nano. Any ideas?
I hope the new widget will be added soon. It’s the only feature that I’m missing.
