How can I edit the App from a sub-organization
How can I edit the app pages from a sub-organization. The user into the sub-organitzation, can’t be developer mode, then is not possible to edit the app.
Thanks in advance,
Joan
Hello. You can’t. You can edit template only from the root organization and only under dev account. It is done due to the security concerns. By system design you can’t access any object from the upper hierarchy.
However, it’s possible under the bussiness plan and only if you created the template under suborg. In that case hierarchy rule is not broken.
