How can I control servo angle using Blynk?
Hi. I’m new to Blynk and arduino. I want to control the angle of my servo. Is it possible using Blynk. Also, I’m using arduino with ESP8266 WiFi Shield. Thanks in advance
Shouldn’t be too hard. Look at Virtual pins. Then you can send over the angle from blynk and have it be a variable you use in Servo.write(variable);
