Hello
I want your help with this plan.
First of all, let me introduce it to you, I use the board nodmcu
I have created 6 zones, an indication for activation-deactivation,
as well as a buzzer.
I control all this with the blynk application.
after I have added the following statements:
case1–alarm on
case2–alarm off
case3–alarm panic
case4–home mode
how can i add a RFID sensor to the program (on-off )
and if I can add a 15-second delay to the input door sensor
what other corrections, additions do you suggest?
thanks
char auth[] = "@@@@@@@";
//char ssid[] = "@@@@@";
char ssid[] = "######";
char pass[] = "@@@@@@";
bool alarm_mode = false ;
bool sensorf = false ;
int alarm_led = 4;
int sensor = 5; //GPIO Pin number on which sensor is connected
int sensor_1 = 13; //GPIO Pin number on which sensor is connected
int buzzer = 15; //GPIO Pin number on which buzzer is connecte
int pir_sensor = 14; //GPIO Pin number on which sensor is connected
int pir_sensor1 = 16; //GPIO Pin number on which sensor is connected
int pir_sensor2 = 12; //GPIO Pin number on which sensor is connected
int pir_sensor3 = 10;
void myTimerEvent(){
if(digitalRead(sensor) == 0){
Blynk.virtualWrite(V0, "CLOSE");}
if(digitalRead(sensor_1) == 0){
Blynk.virtualWrite(V2, "CLOSE");}
if(digitalRead(pir_sensor1) == 0){
Blynk.virtualWrite(V3, "CLOSE");}
if(digitalRead(pir_sensor2) == 0){
Blynk.virtualWrite(V4, "CLOSE");}
if(digitalRead(pir_sensor) == 0){
Blynk.virtualWrite(V5, "CLOSE");}
if(digitalRead(pir_sensor3) == 0){
Blynk.virtualWrite(V6, "CLOSE");}
if(digitalRead(sensor) == 1){
Blynk.virtualWrite(V0, "OPEN");
if(alarm_mode == true){
Blynk.notify(" DOOR is open, Alarm Mode ON");
digitalWrite(buzzer, HIGH);
if(digitalRead(sensor_1) == 1){
Blynk.virtualWrite(V2, "OPEN");
Blynk.notify("WINDOW is open,Alarm Mode ON");
digitalWrite(buzzer,HIGH);
if(digitalRead(pir_sensor1) == 1){
Blynk.virtualWrite(V3, "OPEN");
if(alarm_mode == true && sensorf == false){
Blynk.notify("ALERT,radar apothikh is open,Alarm Mode ON");
if(digitalRead(pir_sensor3) == 1){
Blynk.virtualWrite(V6, "OPEN");
Blynk.notify("ALERT,RADAR @@@@@@ IS OPEN,ALARM MODE ON");
if(digitalRead(pir_sensor2) == 1){
Blynk.virtualWrite(V4, "OPEN");
Blynk.notify("ALERT,radar paidiko is open,Alarm Mode ON");
if(digitalRead(pir_sensor) == 1){
Blynk.virtualWrite(V5, "OPEN");
Blynk.notify("ALERT,radar saloni is open,Alarm Mode ON");
BLYNK_WRITE(V1) {
switch (param.asInt()) {
case 1: { // Item 1
Serial.println("Item 1 selected");
alarm_mode = true;
sensorf = false;
digitalWrite(alarm_led, HIGH);
break;
case 4: { // Item 4
Serial.println("Item 4 selected");
alarm_mode = true;
sensorf =true;
digitalWrite(sensor, HIGH);
digitalWrite(alarm_led, LOW);
break;
case 2: { // Item 2
Serial.println("Item 2 selected");
alarm_mode = false;
sensorf = false;
digitalWrite(buzzer, LOW);
break;
case 3: { // Item 3
Serial.println("Item 3 selected");
alarm_mode = false;
sensorf = false;
break;
BLYNK_CONNECTED() {
Blynk.syncAll();
pinMode(sensor,INPUT_PULLUP);
pinMode(buzzer,OUTPUT);
pinMode(alarm_led,OUTPUT);
pinMode(pir_sensor,INPUT_PULLUP);
pinMode(sensor_1,INPUT_PULLUP);
pinMode(pir_sensor1,INPUT_PULLUP);
pinMode(pir_sensor2,INPUT_PULLUP);
pinMode(pir_sensor3,INPUT_PULLUP);
//timer.setInterval(500L, myTimerEvent);
