I suppose, this might be connected to some old data the the widget remembers, but i thought that the admin - user apps have rather a master - slave relationship, and so if I see everything ok, than the users should see the same?
All of the variables monitored by the history graph have a low-pass/high- pass filter on their Labeled Display Widgets (blynk side, not hardware) set to 0-100.
Also on her version of the history graph widget you can see the fourth variable which is not connected to anything and in my app - correctly nothing in the legend is there shown.
BTW - I don’t use the “mapping” function in display’s because you’ve written somwhere in the forum that it is same as if i used map(0,1023,0,100); but how do you know that the input max is 1023 if I don’t specify it? Maybe my max value is 4096? How does it work? Where this function get the original min-max values from?
I have the latest version, and my friend just installed Android version fresh three/four days ago.
I had the Y-AXIS MIN/MAX set to auto, since I wanted the widget to automatically scale in a given time period. Now I changed it to custom: 0 … 100
I asked my friend to send me a screenshot after checking for newest blynk version, and rebooting blynk. We will see did it make the change.
But it’s not a real sollution, since I would like to have AUTO mode on, so that the data is clearly visible and takes all the available space.
@ethelder
Change back to the auto mode and it should work.
@BlynkAndroidDev This is same as we had with buttons - old widgets stored on server have autoYCoords flag zero. Please add checkBackwardCompatibility to check min/max equals.
Also, good point to not show a legend if pin is not assigned.
@eugene
Thanks very much. Now the app works, like it should. Tell me please (and the community) for the future use, was that a bug in my app only, and can happen in future projects of mine or someone elses, or is your fix permanent?
BTW - you’ve written “old widgets stored on server”, and this led me to tell you one #lifehack i do frequently with blynk to debug all the issues. I create one project for prototyping of my app, do all the changes and when I have the 1.0 version ready, I delete the project on blynk, and create a new fresh one from scratch with all the correct Virtual pins and make no changes from that point on. If I need to make some minor changes I always abbandon used Virtual Pins and never reuse them - I use fresh ones. With each BIG update of my firmware on the hardware, I also delete the app and create a fresh one.
@Dmitriy
I meant BIG updates of MY firmware - which consists of changes to the data I’m sending being reorganized, and so - the virtual pins reorganization:)
