Hi All,
I was wondering if anyone else has experienced this very strange problem?
I have a project that works fine against the blynk.cc servers, but doesn’t show live data when using my local server.
I can look at the historical data in a SuperChart (for any of the non live time ranges), but the “Live” time range shows nothing (note that when I change time range, I do see the data that has been received since the last change). So data is definitely being accepted from the nodemcu module by the local server. Value Displays also don’t show any values either.
I have a very simple test project consisting of:
1x NodeMCU
1x DHT22 (on pin D4)
I’ve setup a local server, running on a Pi on Raspbian (following the instructions), but running under a dedicated standard user account. I’ve setup custom ports and opened these up in Raspbian:
$ sudo ufw status verbose
Status: active
Logging: on (low)
Default: deny (incoming), allow (outgoing)
New profiles: skip
To Action From
37952 ALLOW IN Anywhere
37344 ALLOW IN Anywhere
37244 ALLOW IN Anywhere
37144 ALLOW IN Anywhere
37980 ALLOW IN Anywhere
37443 ALLOW IN Anywhere
37952 ALLOW IN Anywhere (v6)
37344 ALLOW IN Anywhere (v6)
37244 ALLOW IN Anywhere (v6)
37144 ALLOW IN Anywhere (v6)
37980 ALLOW IN Anywhere (v6)
37443 ALLOW IN Anywhere (v6)
server.properties:
# Application mutual ssl/tls port
app.ssl.port=37344
# Hardware plain tcp/ip port - Default hardware port that needs opening
hardware.default.port=37244
# Hardware ssl/tls port (for hardware that supports SSL/TLS sockets)
hardware.ssl.port=37144
#Http and web sockets port
http.port=37980
#Https, web sockets, admin port
https.port=37443
I have forwarded only the following through my broadband router
app.ssl.port
hardware.ssl.port
The NodeMCU code, that I have already successfully tested against the blynk.cc servers (sensitive values *** out).
* This example shows how value can be pushed from Arduino to
* the Blynk App.
* WARNING :
* For this example you will need SimpleTimer library:
* and Adafruit DHT sensor library:
* App project setup:
* Value Display widget attached to V5
* Value Display widget attached to V6
#include <DHT.h>
char auth[] = "********";
char ssid[] = "********";
char pass[] = "********";
#define DHTPIN D4 // What digital pin we're connected to
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
DHT dht(DHTPIN, DHTTYPE);
Blynk.begin(auth, ssid, pass, "****.dtdns.net", 37244);
dht.begin();
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t))
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
Blynk.virtualWrite(V7, millis() / 1000);
Serial.print("Tempurature: ");
Serial.print(t);
Serial.print(" , Humidity: ");
Serial.print(h);
Serial.print(" , Seconds: ");
Serial.println(millis() / 1000);
if( t > 40.0 ) {
Serial.println("Tempurature above 40.0");
Blynk.notify("Tempurature above 40.0");
My Blynk mobile app consisting of:
2x Value Displays
- Humidity V5
- Temperature V6
1x Super Chart - Humidity V5
- Temperature V6
- Uptime V7
Any help, or debugging suggestions would be gratefully received.
Neil
